C6 Zo6 Shifter Install
Old Jul 24, 2007 | 01:07 AM
RIDE3311's Avatar
RIDE3311
Default C6 Zo6 Shifter Install
Hey guys,
I had a quick question. My 07 C6ZO6 shifter should be arriving tomorrow and I think it comes as a full assembly not just the shifter that bolts on with the four bolts. My question is what do you torque the bolts to that go into the torque tube? Do you need to torque them to any specific ft/lbs or do you just use lock tight and get them as tight as possible?
Here is a pic to show you guys what I'm talking about:
http://redshift.homestead.com/C6shift/C6shift9.jpg
Thanks guys,
Harshil
Old Jul 24, 2007 | 07:44 AM
Patches's Avatar
Patches
Here's my C6 installation thread.
C6 Shifter installation
http://forums.corvetteforum.com/show....php?t=1022661
I referenced my Hurst install within it which gives you the torque specs.
Hurst Installation
http://temp.corvetteforum.net/c5/pat...rInstall.shtml
Old Jul 24, 2007 | 03:35 PM
RIDE3311's Avatar
RIDE3311
Thanks Patches
I actually took this picture from your C6 shifter install write-up. I didn't know that the torque specs were on the hurst install.
Thanks again,
Harshil
Old Jul 24, 2007 | 03:53 PM
RIDE3311's Avatar
RIDE3311
Patches,
I needed the torque specs for the two torx bolts that go into the torque tube. In the hurst install it has the specs for the four bolts that directly go through the shifter base. Do you know what you tightened the two torx bolts to on the torque tube when you installed the full shifter assembly?
Thanks,
Harshil
Old Jul 24, 2007 | 08:19 PM
Patches's Avatar
Patches
22 lb. ft.
The shift rod clamp bolt is also torqued to 22 lb. ft.
Old Jul 24, 2007 | 08:22 PM
RIDE3311's Avatar
RIDE3311
Thanks Patches!!
Old Jul 24, 2007 | 10:17 PM
YeloFevr's Avatar
YeloFevr
Tighten to:
"Ahh, that seems tight enough" lb. ft.
Old Jul 25, 2007 | 12:28 AM
RIDE3311's Avatar
RIDE3311
Originally Posted by YeloFevr
Tighten to:
thanks YeloFevr
Harshil
Old Jul 25, 2007 | 01:14 AM
NOS500's Avatar
NOS500
Tighten to:
Thats what i did.
To C6 Zo6 Shifter Install
