Key won't turn & wheel does not lock!
Old Jul 24, 2007 | 02:48 PM
jlow1015's Avatar
jlow1015
2nd Gear
Default Key won't turn & wheel does not lock!
My 2000, automatic is acting up again! The key does not turn at all and the wheel does not lock. Have tried to turn wheel in both directions while trying to turn the key, and nudge the gearshift while turning the key... NOTHING!
I hate to have it towed if is something minor. Anyone else ever have this happen? What is the fix?
jlow1015
Old Jul 24, 2007 | 04:40 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
jlow1015
Have you tried another key ?
Also might try cleaning the key with some alchol.
Old Jul 24, 2007 | 06:55 PM
spiral04's Avatar
spiral04
A few months back I stopped at a gas station to get some gas. When I got back in the car, the key wouldn't turn. I had to have it towed to the dealer. It ended up being something with a solenoid. Hope you get it figured out.
Old Jul 26, 2007 | 10:48 AM
jlow1015's Avatar
jlow1015
2nd Gear
Default key won't turn
Problem solved...
The reason the key would not turn was a bad ignition lock cylinder.
Old Jul 26, 2007 | 11:10 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Problem solved...
thanks for posting the solution, good info to pass on
To Key won't turn & wheel does not lock!
