Crack in Suspension Spring
Old Jul 24, 2007 | 09:13 PM
Bluemill's Avatar
Bluemill
Default Crack in Suspension Spring
I have a longitudinal crack right down the middle of my "popsicle stick" front fiberglass spring that I discovered the last time I changed the oil. The car seems to ride well, and aside the usual c5 bumping the nose pulling into driveways and parking lots because of the overhang, I don't thing I'm riding too low. The spring is still in one piece, but the crack is pretty deep in most of its length.
Is this Corvette abuse? Or is this a hazardous situation?
Can an advanced shade tree guy with a compressor, good tools and a garage do this or should I bring this to a pro?
Thanks,
Bluemill
Old Jul 24, 2007 | 09:45 PM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Thanks,
Bluemill
You can remove that spring yourself very easily at home. I R&R'd the rear and front in two hours.
-RR
Old Jul 24, 2007 | 09:54 PM
Bluemill's Avatar
Bluemill
Default Should I and what kind?
Should I go after market? -Or GM? Is it a must do soon?
Old Jul 24, 2007 | 10:08 PM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Depends really. There are too many varaible to give you a straight answer "yes" or "no". If you are happy with the handling of your car then just replace it with the OEM. If not then you have decide long range goals i.e. road race, aggressive street etc.
Use this link for guidance on the install.
Enjoy,
-RR
Old Jul 24, 2007 | 10:37 PM
Bluemill's Avatar
Bluemill
Default Great how to, step by step.
Thanks, the how to is awsome, and I didn't see any ball joint pulling which is nice. Now to shop for springs!
Bluemill
Old Jul 24, 2007 | 10:58 PM
jon c's Avatar
jon c
now would be the time to go with coilovers
Old Jul 25, 2007 | 06:35 PM
Bluemill's Avatar
Bluemill
Default OK, what's a coilover?
Is this a way to cover up the cracks you have in your fg popsicle stick?
I think I'm just going with the soft ride regular front, but without the crack! Corvette America has an application for $350. NTB
Old Jul 25, 2007 | 07:33 PM
BlackZ06's Avatar
BlackZ06
By "Coil Over" what is meant is a more "traditional" spring set-up. Instead of the leaf spring, you put in coil springs that wrap around the shock absorbers (dampers). Expensive conversion, usually done when you want a stiffer "performance" suspension.
Which suspension option do you have in the car ?? The F45 (F55) suspension uses a different spring than the FE1 and other suspension systems. If you are switching to a different front spring, you should consider a matching rear spring. Mis-matched spring rates can lead to significant oversteer/understeer being introduceed to the car.
Old Jul 25, 2007 | 09:04 PM
jetning's Avatar
jetning
checkout Vette Brake Products, an aftermarket.
Old Jul 26, 2007 | 12:15 PM
BanditDude's Avatar
BanditDude
Actually, I'm fairly certain that the F45 used the base FE1 springs. The only other stock spring options were Z51 and Z06. The difference between the latter two sets was that the rear Z51 spring was ~10% softer than the Z06 rear.
Good luck in your search.
Old Jul 26, 2007 | 02:57 PM
Bluemill's Avatar
Bluemill
Default Thanks for the advice........
It appears that the Corvette catalog houses aren't really well stocked on this item, or they are really pricey, like $500.00 and up.
Thanks for the tip on Vette Brakes and Products- I'll see what they have. My car has the soft ride suspension, which is great for the daily driver that it is, and me cuz I'm no kid looking for a race all the time. Looks like I can get out of this on the cheap side in that I don't have real time damping or the fancy Z-51 suspension.
Thanks,
Bluemill
Old Jul 26, 2007 | 06:31 PM
BanditDude's Avatar
BanditDude
If you're simply replacing the front spring, I definitely wouldn't buy it new from a dealer. There's lots of folks that have upgraded and have them cluttering up their garages. A quick WTB post in the for-sale section would probably yeild several of them for a fraction of the cost ($100 or less).
The FE1/F45/F55 springs are the same. Then comes Z51 (FE3 suspension) and the Z06 (FE4 suspension). So...you'd have several cars to get parts from if replacing an FE1 front. Good luck.
Spring Rates
439.66 lb/in, front; 576.70 lb/in, rear (manual trans); 588.12 lb/in, rear (auto trans) --- FE-1/Base --- Source
440 lb/in, front; 577 lb/in, rear --- FE-1/Base --- Source
457 lb/in, front; 577 lb/in, rear --- MSRC --- Source
525 lb/in, front --- FE-3/Z51 --- Source
660 lb/in, front --- FE-3/Z51 --- Source
327 lb/in, rear --- FE-3/Z51 --- Source
633 lb/in, rear --- FE-3/Z51 --- Source
634 lb/in, rear --- FE-3/Z51 --- Source
525.31 lb/in, front; 633.80 lb/in, rear (manual trans); 645.22 lb/in, rear (auto trans) --- FE-3/Z51 --- Source
525 lb/in, front; 634 lb/in, rear --- FE-3/Z51 --- Source
620 lb/in, rear --- FE-4/Z06 --- Source
650 lb/in, front; 680 lb/in, rear --- FE-4/Z06 --- Source
525 lb/in, front; 714 lb/in, rear --- FE-4/Z06 --- Source
650 lb/in, front; 800 lb/in, rear --- T1 --- Source
1,000 lb/in, front; 680 lb/in, rear --- Danny Popp's setup --- Source
77 N/mm --- FE1 & F45 front suspension spring rate --- SAE SP-1282
1.15 Hz --- FE1 & F45 front suspension ride frequency --- SAE SP-1282
103 N/mm --- FE1 & F45 rear suspension spring rate --- SAE SP-1282
1.36 Hz --- FE1 & F45 rear suspension ride frequency --- SAE SP-1282
1.18 --- FE1 & F45 Ride frequency ratio --- SAE SP-1282
93 N/mm --- FE3 front suspension spring rate --- SAE SP-1282
1.20 Hz --- FE3 front suspension ride frequency --- SAE SP-1282
113 N/mm --- FE3 rear suspension spring rate --- SAE SP-1282
1.45 Hz --- FE3 rear suspension ride frequency --- SAE SP-1282
1.21 --- FE3 Ride frequency ratio --- SAE SP-1282
To Crack in Suspension Spring
