Car won't start?? HELP!
Old Jul 25, 2007 | 07:25 PM
thorn92's Avatar
thorn92
Default Car won't start?? HELP!
My buddy's 03 Z06 MN6 was running fine yesterday and when he got up today it wouldn't start. He said all lights work, the fuel pump pressurizes, the guages sweep and when he turns the key, it won't turn over and there is no sound at all? He checked the clutch switch and it was good. He took the battery to AutoZone and it checked out fine. He still charged the battery and still no luck. Also, he checked the fuses and they were all good. Could it possibly be the starter froze? Or a relay? Any help is greatly appreciated. Thanks!!!
Old Jul 25, 2007 | 08:19 PM
jackson01's Avatar
jackson01
I had the same thing happen after an autocross event. Loaded up on the trailer and when I got home it wouldn't start. It was the starter.
Old Jul 25, 2007 | 09:36 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yeah, first thought was the clutch switch which you said was already checked. The security system could be the issue too. Clean the pellet on the key. Security light complaining in some way?
Old Jul 27, 2007 | 03:57 AM
thorn92's Avatar
thorn92
Thaks guys. He sdaid he got it working. He ended up tapping on the starter and rolling the car back in forth while in reverse and in a higher gear...finally the starter popped back out. Ended up, it was stuck in the flywheel!! thanks again!!
To Car won't start?? HELP!
