O2 sensor which one is front and rear? CODES...
Old Jul 26, 2007 | 04:02 PM
Freddy_97_C5's Avatar
Freddy_97_C5
Default O2 sensor which one is front and rear? CODES...
I have found the sensors I need to replace which are these o2 sensors
P0135, P0155 are they before the catylac converter or after? Are they left or right.
Please help
Old Jul 26, 2007 | 04:55 PM
GUSTO14's Avatar
GUSTO14
Heater Circuit Bank 1 Sensor 1... Heater Circuit Bank 2 Sensor 1...
Both your left and right O2 sensors, I would guess the front ones, but I'm not 100% positive. You might try unplugging them and reseating the plugs to see if there is a continuity issue with the heater elements in them.
Good luck... GUSTO
Old Jul 26, 2007 | 05:03 PM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
Good luck... GUSTO
yup thats both front 02's
Old Jul 26, 2007 | 05:11 PM
Freddy_97_C5
Default Outstanding
I just called local parts store has all $ of them
Bank1= side that has cylinder 1
Bank2= side that has cylinder 2
Sensor1= Front O2 sensors
Sensor2= Rear O2 sensors
I hope this fixes the dang check engine light and the stupid code stuff
Thanks to all !
Old Jul 26, 2007 | 09:30 PM
PugLover's Avatar
PugLover
I had to change bank 2 sensor 2 to fix my check engine light. Pretty easy to change. Good luck
Mark
Old Jul 27, 2007 | 12:42 PM
Freddy_97_C5
Default No Check Engine Light
I replaced my left and right O2 sensors which only took about a whole 10 minutes for both.
RESULTs:
-Check engine light went out
-Cleared codes after a reset
-Engine is idling much better
-Life is Good...
when your Corvette is running good
Thanks for the help hopefully it keeps running good
To O2 sensor which one is front and rear? CODES...
