How to clear codes
Old Jul 27, 2007 | 02:33 PM
4SFED Z's Avatar
4SFED Z
Default How to clear codes
Ok I know how to scan my car using the butons on the side of the console....but is there any way to clear them out. I am having traction control/abs/and ebcm problems and I want to know if I could clear the code to see if it comes back. Thanks
Old Jul 27, 2007 | 02:52 PM
rws.1's Avatar
rws.1
once you have run the codes and are in the manual mode you can use the option button ( i think) to scroll down thru the list...
At any point when a code is dsiplayed depress and hold the rest button....
It may take 3-5 seconds but eventually you will hear a beep and the code will be deleted..
Old Jul 27, 2007 | 02:55 PM
Bruceatlam's Avatar
Bruceatlam
After they all "roll" through in sequence you can scroll through them one at a time and just press "reset" on your DIC buttons to clear the code.
See this thread for buttons to push:
https://www.corvetteforum.com/techti...D=26&TopicID=1
To How to clear codes
