Problems with reverse
Old Jul 29, 2007 | 02:25 AM
im-vettin-on-it's Avatar
im-vettin-on-it
Default Problems with reverse
i have a 98 anyone have problems where they have to hold reverse in place or it pops out of gear???
Old Jul 29, 2007 | 12:18 PM
TLewis4095's Avatar
TLewis4095
Bent fork. Where are you located? Along with us there are several shops that can fix this for you without it costing a fortune.
Old Jul 30, 2007 | 10:10 PM
im-vettin-on-it
Default Im in virginia beach
im located in virginia beach, about how much is this going to cost, and do they have to remove the transmission? Im just asking because if so I will go ahead and have a clutch installed. Thanks for your help
Old Jul 31, 2007 | 12:46 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
My last and final issue with my '99 MM6 tranny was it was jumping out of reverse. Turned out to be a burned bushing inside which in turn ruined a bunch of other items. This was the 3rd major issue therefore I gave up and bought a new trans for it. No problem since. First issue was bad synchros and a gear, 2nd issue was the mainshaft is association with 5th and 6th gear and the splines on the main shaft.
Old Jul 31, 2007 | 08:19 AM
TLewis4095's Avatar
TLewis4095
Yes the tranny will need to be removed & it is a good idea to replace the clutch while everything is apart. Carolina Auto Masters is in NC, they are capable of the job....someone else chime in if there is a closer shop they know off. Good Luck!
To Problems with reverse
