Question: Front Bumper crash rating
Here are some answers to a FAQ document from NHTSA:
What is the purpose of bumpers?
The car bumper is designed to prevent or reduce physical damage to the front and rear ends of passenger motor vehicles in low-speed collisions. Automobile bumpers are not typically designed to be structural components that would significantly contribute to vehicle crashworthiness or occupant protection during front or rear collisions. It is not a safety feature intended to prevent or mitigate injury severity to occupants in the passenger cars. Bumpers are designed to protect the hood, trunk, grille, fuel, exhaust and cooling system as well as safety related equipment such as parking lights, headlamps and taillights in low speed collisions.
3) What are the Federal regulations for bumpers?
49 CFR Part 581, "The bumper standard," prescribes performance requirements for passenger cars in low-speed front and rear collisions. It applies to front and rear bumpers on passenger cars to prevent the damage to the car body and safety related equipment at barrier impact speeds of 2½ mph across the full width and 1½ mph on the corners.
This is equivalent to a 5 mph crash into a parked vehicle of the same weight. The standard requires protection in the region 16 to 20 inches above the road surface, and the manufacturer can provide the protection by any means it wants. For example, some vehicles do not have a solid bumper across the vehicle, but meet the standard by strategically placed bumper guards and corner guards.
9) How does the U.S. the bumper standard compare to the Canadian and European standards?
Under the Canadian bumper standard, the vehicle is impacted into a fixed-collision barrier that is perpendicular to its line of travel while the vehicle is traveling longitudinally forward at 8 km/h (5 mph) and longitudinally backward at 8 km/h (5 mph), with its engine operating at idle speed. Every vehicle is impacted twice on the front and rear surfaces and once on each front and rear corner with the impact line at any height between 500mm (20 inches) and 400mm (16 inches). While the impact speed in the Canadian standard is higher than that in the U.S. standard, the Canadian standard has less stringent protective criteria. Specifically, the protective criteria for the Canadian standard requires that the vehicle does not touch the test device, except on the impact ridge with a force that exceeds 2000 lbs. on the combined surface of the test device.
The United Nations Economic Commission for Europe (ECE) regulation No. 42 requires that a car's safety systems continue to operate normally after the car has been impacted by a pendulum or moving barrier on the front or rear longitudinally at 4 kilometers per hour (about 2.5 mph) and on the front and rear corner at 2.5 kilometers per hour (about 1.5 mph) at 455 mm (about 18 inches) above the ground under loaded and unloaded conditions.
Bill
