DTC B0605 BCM internal memory malfunction, BCM death code?
Old Jul 31, 2007 | 01:53 PM
White92lt1's Avatar
White92lt1
Default DTC B0605 BCM internal memory malfunction, BCM death code?
My 2001 Z06 is dead. However, I can pull/reinstall the BCM/CLSTR #25fuse or disconnect/reconnect the battery and everything is back to normal. The car will go back to it's dead mode (no interior light, no start, DIC shows "reduced power" and "service traction, abs,etc") after turning off the ignition. Alll seemed to start after I connected the hood light plug (near the radiator) after finding it unplugged (of course I disconnected it after having the BCM problems). I have no other blown fuses. I hope I can find a solution before buying a new BCM.
