Shifting my A4
Old Aug 1, 2007 | 05:55 PM
KC2004's Avatar
KC2004
Default Shifting my A4
No snide comments please. I have a 04 A4 and sometimes I like to run thru the gears manually. Its fun but I am glad I don’t have to do it all the time. I don’t have a paddle shifter or anything like that just 1 2 3 D. (I don’t even know if they offer a paddle shifter for these cars) The question is can I do any damage running through the gears manually. Can I drive the car hard doing this or is that not recommended. It's mostly so I can play with the sound of my Borla Stingers.
Thanks in advance
KC
Old Aug 1, 2007 | 06:30 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I've heard that its not all that good on the trans to do it that way--but you'll find people on both sides of the issue so i can't really say for sure----I do know that I drove my own A4 thru the 1/4 --once shifting manually and then shifting with the computer---and i have to say the computer did a far better job than I--was 2 tenths quicker---and i have over 1000 runs under my belt---its really easy to mess-up the 1-2
shift as it comes so fast--i would either miss it or short shift
Old Aug 1, 2007 | 10:42 PM
JEEP/C5's Avatar
JEEP/C5
This subject has been discussed before - do a search. I would think It would not hurt it but over time it may wear out the linkage to the tranny. I had an old celica that I shifted manually (A4) every day for 5 years with no problem (the car was a dog unless I did the shifting). I do shift mine C5 (A4) somtimes to get the corsa sound and to feel the power but not as much as I use to. If you enjoy shifting manually then I would say go for it.
Old Aug 2, 2007 | 01:12 AM
Icewind Dale's Avatar
Icewind Dale
Hate to say it but if your shifting enough to be concerned for your tranny you should probably consider a 6-speed.
Old Aug 2, 2007 | 07:55 AM
sarchevyman's Avatar
sarchevyman
I am just like you, don't want a 6-speed, but do like to shift the gears once in a while, I have been doing it for about a year now and have not notice any issues. Plus if I want to shift gears I jump in my 68 and throw them around all day
Old Aug 2, 2007 | 08:50 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I keep mine in D3 around town....like the sound and figure it saves the converter some unecessary work...........
Old Aug 2, 2007 | 09:05 AM
C5Natie's Avatar
C5Natie
Old Aug 2, 2007 | 06:11 PM
Dave00C5's Avatar
Dave00C5
It should not hurt a thing. Have fun drivin it!
Old Aug 2, 2007 | 07:01 PM
nmbis2k's Avatar
nmbis2k
My thought is that the 4L60E can take it. Just keep an eye on trans temp, and service the trans routinely.
I run the B&M stacked plate aux. cooler, and changed the filter at 12k, and a flush and fill at my Chevy dealer at 20K.
Now have 25k on my 2000 C5 coupe.
Plus, when the trans breaks, they are very cheap to repair/replace because there are millions of them in service.
Old Aug 2, 2007 | 07:06 PM
R Devil's Avatar
R Devil
Old Aug 2, 2007 | 09:33 PM
vette dan's Avatar
vette dan
Vette Dan
Don't know where you are buying , but a new tranny for my A4 97 was $3K.
Old Aug 3, 2007 | 04:08 AM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
Thanks in advance
KC
Don't worry dude, I have an '04 A4 at home too and I do the same thing on occasion. The only thing you are damaging is your fuel economy, but I don't think you care about that too much
Old Aug 3, 2007 | 11:22 AM
David426's Avatar
David426
Just watch the trans temperature.. They can get real high when manually shifting... Heat is the killer of these transmissions
To Shifting my A4
