Using Colder thermostat with larger Radiator
Old Nov 3, 2001 | 03:08 AM
team-zr1's Avatar
team-zr1
Default Using Colder thermostat with larger Radiator
I began testing the effect of using colder then stock water radiator thermostats.
I purchased a 178 stat from Eckers and installed it on my '99 Mallett 475 that has a race radiator of Be-Cool.
In 70 degree weather on the highway the water temps never got over 163 degrees in a 40 mile test run. I stayed in 5th gear and with a 3.73 rear end gear to keep more stress onto water temps with speeds up to ..
well you know, up there ;)
Interesting since the stat is 178 degrees.
Only sitting at a stop light would the temps get to 178 degrees.
I tracked down the vendor of the stat which is Vinci HiPerformance and talked to the engineer and find that these stats have a bypass bleeder circuit and due to the radiator design removing heat so well, the stat bypass is too large.
Vinci is making me a custom stat with a smaller bypass and I should get it in about a week to install and test.
If it works out well then that vendor will have to start making these for those also using a race type radiator.
Old Nov 3, 2001 | 04:41 AM
Austrian Vette's Avatar
Austrian Vette
Default Re: Using Colder thermostat with larger Radiator (team-zr1)
Intresting!!!
Thanks for the info!!! :cheers:
Michael
