4.10s Better traction?
Old Aug 2, 2007 | 08:02 PM
vettegator005's Avatar
vettegator005
Default 4.10s Better traction?
Ive heard both ways about 4.10 gears. Ive heard some people say that the wheels are actually spinning slower so off the line you should get better traction. Then ive heard some people say thats totally bogus and that the wheels are spinning way faster than stock so traction will be horrible. Which is it? I would really like to know and i know people on here can help.
Old Aug 2, 2007 | 08:09 PM
LF97C5Vette's Avatar
LF97C5Vette
Think about it. You LOOSE MPH in each Gear. So if you have your tires Broken Loose at Redline in 1st gear with 3.42's your top speed in 1st is what, 57MPH? And with 4.10s, your top speed in first is ~45MPH? So, who's got less traction?
The thing is, 4.10s increase your mechanical advantage. Which will make it easier for you to break the tires free, since the engine has better 'leverage' however, once they're spinning, they are definately spinning slower, and it should be slightly easier to recover.
I'm so tired of the "You've got no Traction" arguement with 4.10s...
If i said I'm putting in a Torquer V2 cam, and Ported heads for ~410-420WHP nobody would say... well, there goes your traction... Why do people jump straight to traction concerns with 4.10s?
There's other things to consider with 4.10s, and yes traction is important, it isn't the deciding factor for whether or not you should get 4.10s...
Also - If you're launching a Car with 4.10s you have to Realize that and Mitigate THrottle accordingly... NO DIFFERENT than launching ANY other M6. You can't just get in and gun it.. you have to find the sweet spot, and hold it. Don't treat it like a M6 w/ 3.42s... I guarantee the M6 w/ 4.10s will Launch Faster and Run a quicker 1/4 mile time..
-Dan
Old Aug 2, 2007 | 08:13 PM
robvuk's Avatar
robvuk
With the same tires, your traction will be the same. The only thing that is affected is your skill at applying the correct amount of power off the line. Practice makes perfect.
Old Aug 2, 2007 | 08:31 PM
nickolbag's Avatar
nickolbag
No you won't have better traction. So what? Get better tires. Just get the gears already, you will love them.
Old Aug 2, 2007 | 08:49 PM
Mike Mercury's Avatar
Mike Mercury
although the higher ratio does indeed reduce the speed the rear wheel turns... you need to get to a 5:1 or greater ratio before the wheel speed is reduced enough to make it help with the launch.
Too many people are book smart on this, but lack experience as to how it relates to the real world. There are no 5:1 or greater gear sets for the C5; so that benefit can't happen on the C5.
Old Aug 2, 2007 | 09:01 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Unless you really care about the extra two hundtreths the 410 will give you in a quarter mile slip go with 3.90's.
I've had both and prefer the car quieter (not as much RPM on the freeway) and not as "busy" to drive (constantly rowing gears with the 4.10's).
Its not like its a night and day difference with the 3.90's but for me the 4.10's were just a little too much without enough benefit to offset the compromises.
Plus, the more engine you build, the less gear you want and need. In the relatively near future I will drop my gear to a 3.73 with the installation of a pretty stout 447 stroker. Even with that drop in ratio the first few gears will be a smoke show on anything less then a well prepped track with sticky tires.
And thats another consideration you need to think about....while some argue a lower gear helps traction, you can throw that out the window on the street with radial tires and any type of decent power under the hood (400+ RWHP)....as you get closer to 500 RWHP even drag radials become useless with too much gear in the lower two gears so if you primarily street drive, you can create traction issues with too much gear multiplication.
Good luck...
Tony
Old Aug 2, 2007 | 09:02 PM
nickolbag's Avatar
nickolbag
Well said!
Old Aug 2, 2007 | 09:12 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
dude, 4.10s are sick! as long as you knowhow to launch the car, it is a much quicker animal. It gives the car a "jump" into the power band.
of course if you mash the gas like a fool, then even a honda will smoke you. just lean on the gas easy and let the gears work for you.
Old Aug 3, 2007 | 06:14 PM
corvette Mark's Avatar
corvette Mark
I really enjoy being able to "roast my tires at will" with my 4.10's.
Old Aug 3, 2007 | 11:19 PM
TwoValveKid's Avatar
TwoValveKid
Why is it this "traction issue" always hot button in the gear threads, but not in blower, nitrous, turbo threads. :p
Old Aug 4, 2007 | 12:20 AM
robvuk's Avatar
robvuk
Originally Posted by TwoValveKid
Why is it this "traction issue" is always hot button in the gear threads, but not in blower,nitrous,turbo threads. :p
Old Aug 4, 2007 | 11:34 AM
Chevy Guy's Avatar
Chevy Guy
Changing gears wont give you more or less "traction" only suspension and tire changes give you more "traction". 4.10's will enable your car to apply power to the ground in a much different fashion. It is much easier to overcome the tire/suspensions "traction" and spin the tires with 4.10's due to increased mechanical advantage. This is true throughout the RPM range.
A friend has 4.10's in his 02 and says that "traction" is a thing of the past. The simple answer to your question is no, it wont give more traction, especially considering driving style and skill.
Old Aug 4, 2007 | 11:40 AM
Mike Mercury
couldn't agree more.
If one wasn't born with the natural talents needed to work a clutch and throttle together at the same time to their maximized advantage... then modding the car (in attempts to overcome this shortness) won't gain anything.
For those without the talents... get an automatic (I did)
Old Aug 4, 2007 | 02:24 PM
TwoValveKid
Exactly what i am thinking. Eliminate the operator as much as possible. Tried the manual thing once...didnt work out...lol
Old Aug 4, 2007 | 02:34 PM
ZeeOSix's Avatar
ZeeOSix
Hummm ... seems to me with lower gears you'll need more traction since there will be more torque at the rear wheels due to the lower diff gears. If you plotted rear wheel torque vs mph/rpm in each gear you would see there is more torque throughout the range. More torque means the tires want to break loose easier.
Old Aug 4, 2007 | 02:48 PM
Mike Mercury
True; unless you can get enough of a gear reduction to where the wheel speed is so slow that you're not overpowering the tires grip-tion.
The pros go with extreme rear axle ratios 5:1 ... 6:1 to create control of wheel spin in first gear. The tires aren't trying to accelerate to high MPH values with first gear; this gives you more control.
But again - the problem with the C5 is that these extreme rear ratios are not available... hence a moot point.
Old Aug 5, 2007 | 12:06 AM
robvuk's Avatar
robvuk
That is understood. But the traction of the original tires and suspension does not change. Power changes, torque changes but the tires still have the same traction they always had. The skill of the driver must change to adapt and control the power to the tires at the limit. There is only more torque and power at the tires if you, the driver, apply too much of the available power. This is where SKILL comes in.
Old Aug 5, 2007 | 12:54 PM
David426's Avatar
David426
interesting
To 4.10s Better traction?
