I've decided I want to go with the 3.73s and a 3200 stall in my stock 01 A4. The car is a weekend driver and I only do short stints on the highway. Very rarely I will do a 70 mile trip on the highway, about once or twice a year.
I am thinkng about doing an ECS supercharger package over a stock bottom in the spring, so I want to make sure I am doing the right thing with the gear/TC setup.
Superchargers generally give you much better low end torque however the centrifugal style doesn't have the bottom end power of a roots or twin screw style. The torque converter will really help with this allowing your engine to rev into a more powerful RPM range.
This being said, you may want to consider a 3.42 setup to retain good milage. 3.73 and larger gears are usually reserved for cars that will see alot of track time. Your TC and supercharger will give you plenty of low end power and you'll still have some to play with on the highway for passing or just having fun... plus you'll have a higher speed range.
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Plan on going the exact same route as you Maddogg. ECS 3.42's and 3200 stall this year, along with ECS supercharger in the future.
Decided on the 3.42's because 3.73 with the supercharger would be overkill. You'll also pay close to 1K more to go with 3.73's since you need to get the 3series carrier (assuming you have 2.73's now), then have Doug upgrade them to the 3.73 cryo's. That extra g' goes directly to the SC install.
Thanks for the advice. I have 3.15s now, and I am kind of used to them. I was told that the difference between the 3.15s and the 3.42s was minimal, so my thought was that the 3.73s would be the most enjoyable. Obviously the TC is going to make a big difference as well, but I want to be sure before I go for the $ that I am really going to feel the difference. Does the TC really make that much of a difference?
Having owned a stall, I think I'd do a bigger stall and smaller gears. You're going to hate gas mileage life for sure. A big stall is a lot more fun than big gears too.
JMHO.......but, I think that 3.73's WITH a stall AND being huffed would be overkill.........you simply will not be able to put that power on the ground........I've got the 3.73's with a 3000 RPM stall without a supercharger, and 1st gear is "hang on and be ready to STEER" time. If you plan on staying naturally aspirated, then go for the 3.73's...........long term if you plan on supercharging, I think you'd be happier with lower (numerically) gears.......as a matter of fact there was a thread here that I read yesterday about one of the people here dropping down in gear ratios because of limited traction with a supercharger...........
Anyone got the 3.42's with a 3200 stall? Is it "hang on and be ready to steer time" compared to the 3.15s with a stock TC? Big difference??
Anyone got the 3.42's with a 3200 stall? Is is "hang on and be ready to steer time" compared to the 3.15s with a stock TC? Big difference??
A friend of mine has a c5 A4 with 3.15 that is stock. I let him drive my 3.73, Yank SS 3600 stalled car and he said it felt 50 hp stronger than his car....i told him to floor it at 25 mph with tc off...all he could say is wtf and shi!...car started smoking the tires bad....started to go sideways. Yea...it's definitely a big difference. Vararam also.
Ya I do .I had a 3.15 stock stall ,changed it out to a 3.42 & a3200 yank ,no comparsion i also went bigger stall 3600 yank after i fried my tranny 2 times , got a flt level with no issues , if i did it over again i would opt with a 3800 stall & a 3:42 gear , i also just bought chris @ Ecs paxton Novi 2k with a Stock bottom end & i Am Using the 3600 yank & 3.42 gears , we decided to also hit this from another angle & thats to put a blower cam in to compensate for the gear,something that comes on strong down low , the car has no problem making the revs up high ,the car should make 550 rwhp relativley easy, if u wanna send me a pm holler me Have a good day
Sounding more and more like a higher stall and a smaller gear.
Maybe a 3600 and a 3.42 will give me what I'm looking for.
If you are installing the supercharger in the near future I would just keep the 3.15 gears and go with 3800 TC for now. Take my word you wont need the 3.73 gears with the SC. Spend the money on a extra large tranny cooler, you are going to need it with the 3800TC & SC.
