question about headers
Old Aug 2, 2007 | 11:59 PM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
Default question about headers
im installing long tubes for an 01 and up on my 2000 this weekend.. im aware of the air tube cnversion and the fact that the tubes can be blocked off and the pump turned off, but i still dont exactly know how.. can you guys give me a link to thorough directions(besides ls1howto) or tell me how to go about this the easiest and/or most efficient way.. thanks
Old Aug 3, 2007 | 01:55 AM
SLPRC5's Avatar
SLPRC5
Well you can have it turned off by a tunner..until than find the fuse for the pump and pull it.
Good luck with the install
Sleeper
Old Aug 3, 2007 | 02:12 AM
OleStraightStick
St. Jude Donor '08
whats up deno! thanks for the reply.. so u can just pull the fuse and it wont mess up the computer? and how do i block off the air tubes? thanks
Old Aug 3, 2007 | 02:23 AM
torchredfrc's Avatar
torchredfrc
I've searched for detailed instructions for the air tube delete and came up empty handed. Does the actual pump need to be removed once you block off the tubes and delete the code in the PCM?
Anyone who has done this make a write-up?
To question about headers
