Drivers Side Signal
Old Aug 5, 2007 | 10:01 AM
johnnycakes's Avatar
johnnycakes
Default Drivers Side Signal
Can someone please tell me how the heck you change the front signals?
is there a trick to this feat?
johnnycakes
Old Aug 5, 2007 | 01:28 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
From underneath the car, you need to remove the front fascia lower closeout panel.
Old Aug 5, 2007 | 01:38 PM
BanditDude's Avatar
BanditDude
You can also pop up the headlights, remove the shroud around it (held on by 2-3 screws) and reach through the opening.
Old Aug 5, 2007 | 06:59 PM
hangpilot's Avatar
hangpilot
Another method is to go in through the brake duct, push the duct aside, and reach in to change the signal/DRL bulb. But size does matter. Big hands won't come out of the hole very easily. I almost got stuck. Get your wife/GF to reach in there do it.
Old Aug 5, 2007 | 11:11 PM
johnnycakes
Thanks for your answers i will try the moving the duct trick
johnnycakes
To Drivers Side Signal
