Help With McLeod Master Clyinder Install
Old Aug 5, 2007 | 06:38 PM
chevybob's Avatar
chevybob
Default Help With McLeod Master Clyinder Install
Hi,
I am installing an adjustable McLeod Clutch Master Clyinder on my 1998 mn6. ( I hate the clutch grabbing towards the top of the petal.) I can not get the new master clyinder to mount on the firewall? It is very frustrating. I can not see very well and after two hours of wiggling and turning I give up.
thanks for any input
Old Aug 5, 2007 | 06:48 PM
myk7's Avatar
myk7
I had luck with sticking it in position as well as I could tell from the engine compartment, then crawling under the dash and looking how it was positioned. I could tell which way I needed to twist it to get it to seat in the hole correctly before the final installation twist. Good luck
