3.73 gears GP by LAPD
Old Nov 4, 2001 | 06:30 AM
Corvette4ever's Avatar
Corvette4ever
Default 3.73 gears GP by LAPD
Here is the deal we worked out with Getrag on C5 3.73 gear sets:
1-11 orders: $1999.95 SHIPPED!!!!
12-40 orders: $1600.00 SHIPPED!!!
We can do it, but all we need is orders!!
Shawn
[Modified by L.A.P.D., 10:49 AM 11/2/2001]
Original post is here http://forums.corvetteforum.com/zerothread?id=176015
[Modified by Corvette4ever, 4:31 AM 11/4/2001]
Old Nov 4, 2001 | 09:49 AM
DAP's Avatar
DAP
Default Re: 3.73 gears GP by LAPD (Corvette4ever)
With a stock car what is top speed in 5th at 5500 rpms, and 6100 rpms?
Old Nov 10, 2001 | 02:15 PM
BluFRC's Avatar
BluFRC
I'm definitely interested in the GP especially at the lower price of $1600 but cannot commit quite yet... have to generate a little more income first... :nopity
Is this strictly a cash only price? Or is plastic okay?
Old Nov 10, 2001 | 04:33 PM
SteveL2's Avatar
SteveL2
2 questions:
(1) Anyone who already has these in an MN6. Can you please let us know the RPMs in 6th gear n the 65 to 75 mph range? I'm just curious as to the noise difference I'd encounter in ordinary highway driving.
(2) Maybe I'll have to make a poll for this one. If you had $1500-2000 to spend on either this or a CAM-only package (e.g., the present MTI deal), which would you go with?
Thanks. :cheers:
Old Nov 11, 2001 | 09:40 AM
Corvette4ever
Default Re: 3.73 gears GP by LAPD (SteveL2)
2 questions:
Thanks. :cheers:
With stock tires, at 70mph you'll at 2400rpm in 5th gear & 1650rpm in 6th gear.
Go to http://www.datascape.net/99z28/gear/
Iam not sure, but I think that the gears would give you more SOTP than the cam due to the increased torque multiplication at the rear wheels. With the cam you start feeling the power at 4000+ rpm. However, at the track I think that the cam would give you better ET & MPH than the gears
[Modified by Corvette4ever, 2:09 PM 11/11/2001]
Old Nov 11, 2001 | 10:58 AM
C54FUN's Avatar
C54FUN
St. Jude Donor '03-'05-'06-'08-'10
Guys, I have the 3.73 rear change over and let me tell you it is a worthwhile mod. As for RPMs @ 70 MPH in 6th gear, my tach sez 1700 RPM. Notice a slightly different tone (a little deeper) from the Corsa Tourings. This is a good price!
Joe
Old Nov 11, 2001 | 03:02 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Guys,
We can do the GP, but before we can offer the $1600.00 price shipped to your door, we have to get 12 confirmed orders for them first.
Let us know and we will take care of all of your C5's.
Thanks!
Shawn
Old Nov 11, 2001 | 08:01 PM
Redvette_22's Avatar
Redvette_22
Default Re: 3.73 gears GP by LAPD (L.A.P.D.)
I have a brand new set of 3.73's that have not been installed yet, and with being laid off from work last week, it doesn't look like I will be putting them in. Is anybody interested in this rear ? It is most likely up for sale.
Old Nov 12, 2001 | 02:48 AM
BluFRC's Avatar
BluFRC
Default Re: 3.73 gears GP by LAPD (Red98C5)
Where are you located? If you are located and the price is right, I might want to talk to you about a deal.
Old Nov 12, 2001 | 06:07 PM
SteveL2's Avatar
SteveL2
Corvette4ever -- thanks for the calculator. It looks amazingly close to the actual numbers provided by C54FUN.
C54FUN -- thanks for the actual numbers. :cheers:
Now, if someone could just convince me that this mod is better than a cam.
:confused:
Old Nov 12, 2001 | 10:01 PM
C54FUN's Avatar
C54FUN
Default Re: 3.73 gears GP by LAPD (dsk888)
Steve, I chose the rear as it really takes advantage of the LS1s torque (the bottom three gears are awesome(!) and the top three more useful). All this and no change in driveability etc. While I have thought about a cam, going in the engine doesn't appeal to me. Choices, that's what it is all about; good luck with whichever you choose.
Dan, the cost to install the rear at was $300. and took just about 4 hrs. for a quality job.
Joe
Old Nov 12, 2001 | 11:40 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
My Gear set install cost $600.
vetterdstr :cheers:
Old Nov 13, 2001 | 01:53 AM
billiam01's Avatar
billiam01
LAPD (Shawn):
What do you charge to put in the 3.73 deal here (labor)?
Old Nov 13, 2001 | 02:53 AM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
Default Re: 3.73 gears GP by LAPD (billiam01)
billiam01,
Labor charge for gear set install is: $450-$550.
You also have to make sure you have a way to get the PCM programmed so you don't run into any problems.
Shawn
Old Nov 13, 2001 | 10:57 AM
SteveL2's Avatar
SteveL2
Default Re: 3.73 gears GP by LAPD (C54FUN)
Joe -- thanks. Your reasoning is my inclination as well, but I'm trying to learn if there is a real acceleration change or if it's just more of a sensation because of the different gearing. I notice you have 13.07 time in your signature. Do you have a before and after relative to when the 3.73s were installed? Thanks again for all your input on this issue.
Old Nov 13, 2001 | 10:59 AM
SteveL2's Avatar
SteveL2
{ snip } You also have to make sure you have a way to get the PCM programmed so you don't run into any problems. Shawn
Shawn -- Do these problems occur on an MN6 and, if so, what are they? Does this also suggest another $500 or so for a PCM programming? Thanks.
Old Nov 13, 2001 | 11:48 AM
George Cooper's Avatar
George Cooper
L.A.P.D.:
Why do you say that you need to have the PCM reprogrammed? While this is true for the auto cars, I know of no reason that this should be so for the M6 cars.
Am I missing something here?
To 3.73 gears GP by LAPD
Old Nov 13, 2001 | 01:32 PM
C54FUN's Avatar
C54FUN
Default Re: 3.73 gears GP by LAPD (George Cooper)
Steve, CARTEK did my rear and reprogramming of my PCM was not required (mine is a M6'er). My understanding from talking with them is that it is required for A4s. As for before and after time comparisons, I haven't been out to the track since the change, but plan to do so this coming Saturday at the Corvette Challenge. I can say this, on the street I can now break the Michelin Pilot Sports free at will in first and second, in fact, if I mash it hard in first, from a slight roll, I can induce wheel-hop. SOTP sez' it is pulling harder in all gears; expect the launch at the track may be adversely affected by all this low end get-up-and-go. Plan to try lower R's and tire pressure and feathering the clutch to overcome. Will let you the results this coming weekend. BTW, my driving skills are not all that great as I find it hard to beat up my ride for the sake of better times. Like the rest of us, I love my ride. Hope all this helps as the rear change does have its cost, but I think its worth it.
Joe
Old Nov 13, 2001 | 01:37 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
George Cooper,
Your speedo is geared for 3.42 gears from the factory. If you change it over to 3.73 gears, your speedo will be off and there is a risk of the DIC throwing codes.
This is what we were told by Getrag.
Shawn
Old Nov 13, 2001 | 01:48 PM
SteveL2's Avatar
SteveL2
Joe -- thanks a ton. This is by far the most detail I've seen someone post on the effect of the gears alone, and it is very encouraging. My tires from a roll won't break loose with the stock gears, and as mature as it might sound, the prospect of having the ability to tear 'em loose is quite inviting. :jester
Good luck this weekend, and even if your #s don't improve because you don't want to thrash your car, please do let us know any further impressions. I have no plans to ever 1/4 mile track my car, but if my 0-60 or even roll to 60 or 70 acceleration is noticeably improved, then I'm all over this mod. :cheers:
