passenger door lock problem solved (for now)
Old Nov 4, 2001 | 11:16 AM
Ram Air Tony's Avatar
Ram Air Tony
Default passenger door lock problem solved (for now)
first thanks for all the help here...... and the instructions on the door panel removal Steve :yesnod:
I ripped the door panel off last night (good idea to roll the window down first ....thanks for that tip br :) ) and checked all the harness connectors and connections by making sure they were ALL tight and making good contact.
Then I just locked and unlocked about 20 times with the fob and it worked every time......BUT one thing I noticed is that if I hit the key twice TOO fast, it wouldnt work......but if I hit it once then waited about a second and then hit it again, it would always unlock the passenger side.....SOOOOOOOO it appears that I had one and/or two problems:
1. loose connector on the DCM...there were about 4 or 5 of them
2. I was hitting the unlock button twich too quickly, but this isnt likely as even the door lock button on teh driver side wouldnt do it
I am going to continue to monitor this and see where it goes, I also got a tip to make sure the drivers side connections were all good on the window, door, mirror contol pad.....I will check it out too :)
so again, it looks like all is well for now and thanks again for all the help....and to those of you that have a similar problem, I would take the door panel off and check for good connections, if that doesnt fix it, then it could be a warranty issue
THANKS C5TECH, Steve, br and everyone else for the good advice ... aint this place great :cool: :cheers:
Old Nov 4, 2001 | 11:17 AM
Ram Air Tony
Default Re: passenger door lock problem solved (Ram Air Tony)
OH and I forgot to ask this question:
is there a way to program the key fob to open BOTH doors on the first push????
thanks
R
A
T
Old Nov 4, 2001 | 12:08 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Options menu :yesnod:
Old Nov 4, 2001 | 01:54 PM
Ram Air Tony
Default Re: passenger door lock problem solved (C-5 TECH)
dayum, I am gonna have to go try that right now....I hadnt ever looked for that before :confused:
thanks
R
A
T
To passenger door lock problem solved (for now)
