Difference between outside or inside air on a/c
Old Aug 7, 2007 | 08:01 PM
gregcook's Avatar
gregcook
Default Difference between outside or inside air on a/c
How can I tell if my outside or inside air vents are working correctly.I have a dualzone and the appropriate buttons light up when touched but I can detect no difference in preformance or fan noise(unlike my other vehicles )
Thanks Greg Cook
Old Aug 7, 2007 | 08:33 PM
LoneStarFRC's Avatar
LoneStarFRC
Thanks Greg Cook
Try comparing vent register temps after letting each setting operate for several minutes.
Old Aug 8, 2007 | 10:42 AM
jovette's Avatar
jovette
with the fan on high, you should be able to immediately tell a difference between outside air, and interior re-circulation settings. If you can't, I'd say the system is not operating properly.
Old Aug 8, 2007 | 01:19 PM
myk7's Avatar
myk7
Yup, there is quite a difference in sound, and the recycled air should be quite a bit cooler.
Old Aug 8, 2007 | 02:14 PM
Robiwan's Avatar
Robiwan
In my car when running on auto hvac, if the outside temp is much higher than the desired set temp, the recirc comes on with the air con, so the car cools air that is getting cooler instead of trying to cool down the hot outside air. If the outside temp and inside temp are close, I don't know that you could tell the difference.
Robi
Old Aug 8, 2007 | 03:46 PM
jovette's Avatar
jovette
Robi
Take the system off of auto for the test to see if recirculation mode is operational, then you won't have this issue.
Old Aug 9, 2007 | 11:44 AM
bighank's Avatar
bighank
Default Check vacuum lines under the battery
There are 2 vacuum lines (hard plastic) under the battery that get eaten away from battery acid. Check if you are getting vacuum on the line coming thru the firewall aand ending with the purple connector. If not go under the hood remove the battery and battery base and mix up a couple of gallons of baking soda and liberally apply it all over the cables and other parts. Replace most of the rotten lines with rubber vacuum hose. The check valve inside the right front fender below the vacuum tank may be shot also. A $4 part in the HELP section at Advance Auto. Many posts on here including mine that detail how to do this. BIGHANK
Old Aug 9, 2007 | 11:53 AM
LoneStarFRC
Another thought: It's possible a damper door actuator is malfunctioning. Try disconnecting the battery for a few minutes. Upon re-connect, the CJ2 (auto system) recycles for testing purposes. If this is actually the problem, that may well fix it. If not, and the damper door actuator is the problem, it can be reset manually but requires the removal of a lot of the dash area to access. There was interesting post on this here just recently, Try a search.
HTH
Old Aug 9, 2007 | 07:09 PM
Showdown's Avatar
Showdown
I just did that on my car, but I used a "T" connector for the vacume lines.
Old Aug 9, 2007 | 07:33 PM
YelloMello's Avatar
YelloMello
Also, if you set the setting to the coldest/hottest it will be that temp on both sides...
Old Aug 9, 2007 | 09:55 PM
waterzap's Avatar
waterzap
Get a little thermometer that you just put in the vents (buy at any auto parts store). Put the system on max, and go driving with air recirculating. Depending on the temp outside, should be in the high 40's or so. If not, you might have a problem. If you cannot diagnose it yourself, take it to an AC shop then...
To Difference between outside or inside air on a/c
