Relocate EVAP soleniod need help
Old Aug 8, 2007 | 06:55 AM
C5Dream2004's Avatar
C5Dream2004
Default Relocate EVAP soleniod need help
I need to relocate the evap valve on the drivers side fuel rail to make room for my fuel rail covers after a maggie install - the evap system conects to the intake with hard plastic lines which push in fitings - Can the line be extended and what type of hoses needs to be used??
Old Aug 8, 2007 | 07:25 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Mine fit fine under the engine covers after I installed a Magnacharger???
Why do you think it needs to be moved or are you just trying to clean up the area.
Old Aug 8, 2007 | 07:28 AM
C5Dream2004
I'm using ACI covers and they lay down farther than LPE or Callaway covers. The hard EVAP line from the valve to the intake is in the way
To Relocate EVAP soleniod need help
