I saw an advertisement in the paper from a local auto parts store selling one of those laser temp gauges. It says it is for automotive use, but exactly what would you measure with it and why?
Tire temperatures, brake rotor temps, component temps, etc.
Bill
Tires - Although the lazers don't work as well as probes for tires, you can measure the two outside edges and the center to determine if you're under or over inflated at the track. Rough measurement is 1 lb of air for every 5 degree difference.
Rotors - You can compare various pads, rotor types, and venting to see what's working for you.
Components - You can check the header pipes to see if one or more cylinders are running abnormally hot. If you have some baseline numbers, you can keep an eye on the differential, tranny, hubs, etc.
I had an old dodge pickup that was running a little rough...I took the laser and hit each tube on the exhaust manifold...got one that was way cooler than the other 7....started there...bad plug wire ended up being the problem, but it gave me a good place to start...I work on Heavy Equipment/trucks also which use alot of Circut breaker type fuses...you can use the laser on the individual breakers to see which ones are heating up and causing a break in the system...hope this helps
Also works good to tell when your steak and fries are ready!
I guess it would be automotive use if your grilling at the track!
The accurateness of those devices vary a lot. Specially with surface color. A mirror surface will give the worst errors. Optimally you want a flat black (or medium well) color for best accuracy. But for automotive use accuracy is normally not a big issue. Like said above in automotive use relative temperature is what your often looking for, like which header pipe (cylinder) is cold, exhaust a little hotter after the cats than before. Also in automotive use temperatures in the ball park are good enough, like "don't grab that brake rotor yet"!
BTW: It is not a laser temp gauge. They are really Infrared thermometers. Often called Laser temp gauges because of the laser which serves no other purpose than aiming.
I just used my infrared thermometer to find out why my 1997 C5 LS1 was throwing codes and running rough. Checking the INTAKE manifold showed one runner much hotter than the others. I ended up pulling that plug and finding no compression. Broken valvespring and rocker. Thermometer told me where to start looking and saved me tons of time troubleshooting other things.
For accuracy you have to change the emissivity sensetivity setting according to what material and its reflectiveness, when you are trying to measure. Its usually in the manual. My old one just broke and I got a new Fluke 561 HVAC pro, on theBay for $90. Its sweeeeeet. http://us.fluke.com/usen/products/Fluke+561.htm
My $24 unit don't have that setting! But even without it I still know not to grab that approximately 174 degree brake rotor!
