Burnt wires
Old Aug 10, 2007 | 12:50 PM
yakisoba's Avatar
yakisoba
Default Burnt wires
I pulled exhaust manifolds recently as part of a head repair. I note that there are some burnt wires under the passenger side manifold. There is a section of wiring harness that goes under that side, and the sleve is burned and melted, and one of the wires is showing copper. I can patch it up easily enough... But I'm afraid it'll burn through again. The wiring harness looks like a total PITA to replace, and I'do not want to. Anyone else seen this? Potential fixes?
Old Aug 10, 2007 | 02:28 PM
MattB's Avatar
MattB
I burned my O2 sensors after a header install, and after that I warp them. Used left over header wrap and works great so far. There are a few options on cooling tapes and such to wrap the wires. I just fully wraped my headers, so I'm thinking that shoud help the situation. I'm still looking at wraping the starter wires and such that get close to the headers.
Old Aug 10, 2007 | 03:01 PM
rws.1's Avatar
rws.1
I found the same thing when I did my header install... ie the stock manifild heat had melted the plastic loom and the insualtion on the wiring.
I cut the wires, as far from the heat source as possible, slid shrink tubing onto each separate wire, shrunk it, put new plastic loom over it and them put heat resistant cloth socks over the whole thing.
I found those socks( tubing) available at a local speed shop. ( silver colored cloth tubing available by the foot off a roll)
Once that was all in place, I slide some more shrink tubing in place, I resolderd the cut wires and shrunk the tubing then wrapped with high heat electricians tape for added measure.
Old Aug 10, 2007 | 04:28 PM
Buckskinner's Avatar
Buckskinner
Just a note, if you're going to splice wires and use shrink sleaving over them, put a very light coating of RTV sealant over the exposed copper then shrink the tubing over that,. Makes for a insulated and watertight seal, eleminating copper corrosion in the solder area.
Old Aug 10, 2007 | 04:48 PM
rustyguns's Avatar
rustyguns
very good!
Old Aug 10, 2007 | 06:13 PM
lionelhutz's Avatar
lionelhutz
Good idea, but better yet is to get the heatshrink with sealer inside it. It's like a glue lining it that melts as you shrink it, sealing the joint. Similar thick wall tubing is used to seal the wire joints under water for submersible pumps.
Peter
To Burnt wires
