Its HERE!!! And now the questions!
Old Aug 12, 2007 | 06:48 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Default Its HERE!!! And now the questions!
Just picked up my first C5...(99 FRC, only 14k miles).
Car is awesome! Love everything about it. Had to drive it 6 hours home. Now.....it seems to me when up above the 40 mph mark I hear either rear end or rear wheel bearing noise? Is this possible with such low mileage? Or is this road noise? runflat noise? Maybe just normal and I am panicing?Yea...thats it....I'm panicng right?
Old Aug 12, 2007 | 07:05 AM
thorn92's Avatar
thorn92
The run flats are rather noisy. After I put non-run flats on, the noise dramatically decreased. I wouldn't think there's enough miles yet for bad bearings. Congrats on your car!!!!
Old Aug 12, 2007 | 07:07 AM
Zozzie's Avatar
Zozzie
It's probably just road and runflat noise as Vetts have no sound dampening. Mine's a bit that way - not even close to being as quiet as my Acura. We did this thread a couple of weeks ago and it was very interesting.
Old Aug 12, 2007 | 07:34 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Thanks...I'm hoping its just road noise!!!
Old Aug 12, 2007 | 09:05 AM
Bob CTS's Avatar
Bob CTS
Congrats on the car, I agree with the road noise.
Old Aug 12, 2007 | 11:57 AM
FRCTony's Avatar
FRCTony
Keep in mind the FRC has less insulation than other models.
As a result, you will hear more noise and feel more heat than the other models.
My car seemed very quite (relatively) after going to non runflats, but after some miles, tire noise has returned.
I'm convinced that wide tires are going to make noise with age, so don't count on tire replacement as a cure.
Old Aug 12, 2007 | 02:58 PM
Ralphyboy's Avatar
Ralphyboy
If it turns out to be road noise, do a search on various threads about sound deadening, and the different kinds of materials you can use for this. Ensolite, dynamaxx, and even good old Frost King foam from Lowe's works for this. Check it out, and welcome to the forum.
Old Aug 12, 2007 | 05:15 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The noice you are probably hearing is the torque tube (it sits in the hump between the seats.
Lack of insulation and runflats don't help any. I doubt you have whell bearing other problems.
Other noise solution is to install a partition.
Old Aug 12, 2007 | 05:24 PM
evo2ls1's Avatar
evo2ls1
Default congrats
congrats you will love it now its time to mod!
To Its HERE!!! And now the questions!
