Textralia Help..
Old Aug 12, 2007 | 02:15 PM
stol3n's Avatar
stol3n
Default Textralia Help..
I installed a new Textralia OZ700 clutch about 5-600 miles ago whenever i installed my longtubes and cam. Now, here recently it almost sounds as if it is slipping. I have noticed that it does not do it when i first start it up. After driving around for a bit it starts to make a squealing noise as it engages? At idle sometimes u can hear it rattling and the squealing sound i am hearing only does it whenever i start off from a dead stop in first or reverse. Any Help?
*side note: i did not install of do the work, i had a local very reputable shop install and do all the work.
Old Aug 12, 2007 | 03:07 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Alot of them chatter when they are first installed but most people say that it will go away
Old Aug 12, 2007 | 04:28 PM
FRC Rob's Avatar
FRC Rob
That's pretty much the nature of the beast with the Tex Z-grip. You can learn to modify your driving technique to minimize the squealing and chattering. It is also very helpful to beat on the clutch every now and then to keep those bad manners in check. Try a few high rpm clutch dumps on sticky tires, and start off in 3rd gear every once in a while...that will do wonders for its driveability.
Old Aug 12, 2007 | 04:53 PM
ZZOOM06's Avatar
ZZOOM06
This post is right on the money! These clutches don't like to be babied!
Old Aug 13, 2007 | 12:27 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Old Aug 14, 2007 | 09:14 PM
stol3n's Avatar
stol3n
really. well, this might explain a lot. i usually only drive the car about once a week, and it is babied 99.9999% of the time.
Old Aug 14, 2007 | 09:26 PM
Jeffs FRC's Avatar
Jeffs FRC
Mine made the squealing sound at around 1k miles and after beating on it some it has not returned since. If you do a search you will find the squealing is quite common. I also had a very slight rattling noise at idle, but I dont notice it anymore. Not sure if its still there or that I just got used to it. It was very faint and you really had to listen for it.
I have the "Z" disc fyi.
Old Aug 15, 2007 | 06:22 PM
molson's Avatar
molson
I never had any issues with mine....no squeeling or chatter
Old Aug 15, 2007 | 11:59 PM
ZZOOM06's Avatar
ZZOOM06
I like this man's way of thinking! Same thing happened to me!
Jimbo
To Textralia Help..
