Suspension question
Old Aug 12, 2007 | 11:58 PM
Tx Ray-C5's Avatar
Tx Ray-C5
Default Suspension question
I have an 04 Vette and my question is..... When I'm on the highway or taking a turn and hit some bumps in the road, the car seems to loose contact with the road and the rear of the dances around.
Is the suspension that stiff on these cars? Or are my shocks worn ?
Stock shocks and springs with Z06 sway bars. And car is "not" lowered.
Old Aug 13, 2007 | 12:11 AM
roushraven's Avatar
roushraven
Coolest Guy Evar!
List your suspension set-up.
-RR
Old Aug 13, 2007 | 08:07 AM
Tx Ray-C5's Avatar
Tx Ray-C5
-RR
setup added
Old Aug 13, 2007 | 08:25 AM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Originally Posted by Tx Ray-C5
setup added
Thanks.
Our cars have a natural tendency to react the way you described under those conditions with the stock set-up at stock ride height. Before doing any serious changes to your suspension I would recommend that you have another alignment. It won't totally eliminate the tendency to "wiggle" over bumps but it can reduce it significantly. I'll dig up some specs for you to consider and PM them to you later.
-RR
Old Aug 13, 2007 | 08:35 AM
Tx Ray-C5's Avatar
Tx Ray-C5
I replaced one of the front lower a-arms about a month ago due to a bad ball joint. I've already had the car aligned.
Old Aug 13, 2007 | 09:00 AM
blue63cpe's Avatar
blue63cpe
Like roushraven said a natrual tendency,find the current car and driver with the road test of the 'much improved 08'. They call that tendency 'scary'.
Old Aug 13, 2007 | 11:42 AM
Tx Ray-C5's Avatar
Tx Ray-C5
Well that sucks !
Old Aug 13, 2007 | 06:46 PM
gjdean's Avatar
gjdean
Cruising
Mine will do this also with the runflats on.
When I have the supercar tires or the slicks it won't.
Old Aug 13, 2007 | 06:58 PM
wuznme's Avatar
wuznme
I was going to say the run flats as well, since the suspension is all stock
Old Aug 13, 2007 | 07:13 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Are you still driving with Run Flat Tires? They cause the car to do exactly what you're describing.
Old Aug 13, 2007 | 09:01 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You could try installing a bump steer kit.
Old Aug 13, 2007 | 09:49 PM
waterzap's Avatar
waterzap
Or non runflat tires...
Old Aug 13, 2007 | 10:01 PM
Tx Ray-C5's Avatar
Tx Ray-C5
I have a full set of new Michelins that came on the car when I purchased it.
Tx Ray-C5's Avatar
Tx Ray-C5
So should I sell my Michelins and buy some Kumo's ??
Old Aug 13, 2007 | 10:05 PM
Gray Ghost GS
If your Michelins are Run Flats, then yes - I would put them up for sale and get a set of Kumho MX - good tire performance for the price. The handling difference is like night and day.
Old Aug 14, 2007 | 08:25 AM
Tx Ray-C5's Avatar
Tx Ray-C5
greeeaat................. anyone want to buy a full set of year old Michelins ???
To Suspension question
