I just got my car back from having some work done and now my side markers, tail lights and dash lights don't come on when I turn my lights on at night. Also I cant turn my fog lights on. The place where I had the work done denies any responsibility and I really don't want to take it back to them. What fuse or relay controlls those functions? What else can it be? Thankyou.
This is for a 2000 manual corvette. Completely stock.
Its The Headlight Switch The Connections Are Worn. I Had The Same Problem A Couple Of Months Ago. I Replaced It Myself. I Paid About 240.00 Bucks For The Unit. It Took About 45min To Intstall.
this exact thing happened to me, i replaced the multifunction switch brand new nothing happened the brake lights side corner marker lights and dash lights still won’t work, and the headlights won’t go down what else do i do
Yes My Headlights Worked But Tails Lights Side Markers And Fogs Were Out Oh And The Dash Lights Also Wern't Working.
same issue here. Replaced my switch with used switch i purchased at a Corvette show. It didn't fix issue. I went back and bought the headlight module 🫣 Still nothing. So I sent my original switch to the guy on ebay "Corvette Tony " I believe it was. He said my switch checked out on the meter but upon visual inspection he thought the H Beam looked suspicious so he "replaced" it. Put the original back in, same issue.. I noticed that the dash lights do come on when i turn the key to start but go out after its cranked and i let off the key.
We are having the same problem with my son’s car. I replaced the switch and it seemed to work, but the first time he drove it and it got dark he got pulled over because they stopped working again. Fusses are all good. What else should we check? This is frustrating.
