accel dfi wide band logging options
Old Aug 13, 2007 | 07:46 PM
yellow94coupe's Avatar
yellow94coupe
Default accel dfi wide band logging options
I'm thinking about buying an Accel DFI Gen VII ECU and an Innovative Motorsports LC-1 Wideband Controller. Would I be able to connect the analog output of the LC-1 to an analog input on the ECU? I see there is a generic 0-5V linear wideband option you can select that should make this work. Does this work for any Accel ECU or does some kind of key need to be purchased to enable any sort of wideband logging?
