Transmission rebuild
Old Aug 14, 2007 | 02:26 AM
soggysailor's Avatar
soggysailor
Default Transmission rebuild
I have a 97 A4 with 160,000 miles. The trans or more accurately the torque converter seem to be getting tired. I'm making plans to have a rebuild and new(3.42) gears installed. Here's my question. What other things should be checked and/or replaced on an early C5 with the milage I have? The car is mostly stock and will stay that way. I saw a mention of torque tube bushings ?
Old Aug 14, 2007 | 02:35 AM
Rhode Warrior's Avatar
Rhode Warrior
There isn't really anything else there to consider as a wear item. I would consider a tunnel plate while you're at it though. Also a transmission cooler, especially if you're going with a higher stall torque converter.
