ls7 motor
Old Aug 14, 2007 | 12:57 PM
JOEY P's Avatar
JOEY P
Default ls7 motor
Will a ls7 motor fit into a c5 corvette 2000
Old Aug 14, 2007 | 03:03 PM
chris308's Avatar
chris308
http://forums.corvetteforum.com/show...&highlight=ls7
Old Aug 14, 2007 | 07:09 PM
LoneStarFRC's Avatar
LoneStarFRC
That however is more of a full blown custom built engine complete with dry sump tank and all the trimmings.
An LS7 can be changed to a wet sump set-up and if necessary, the reluctor wheel on the crank can be changed in order to keep the factory C5 LS1 PCM. Other than that a complete LS7 crate engine can be dropped right in. Just needs a couple wiring harness adapters and of course a tune as well.
HTH
Old Aug 15, 2007 | 09:55 PM
LS7 C5's Avatar
LS7 C5
But you will have to take the crank out to change reluctor.
HTH
To ls7 motor
