Rear Makeing A 'VIBE'
Old Aug 14, 2007 | 06:36 PM
SILVER ZO6's Avatar
SILVER ZO6
Default Rear Makeing A 'VIBE'
I Live In Frederick, MD AND OWN A 03' ZO6. Just Got My Car Back From Cartek.i Got A Clutch Put In And 390 Gears Installed.i Drove It From Cartek, Home. I Did The Heat Cycles Like You Are Supposed To. All Of A Sudden My Car Started Making A Vibrating Noise Comming From Underneath My Seat And Left, Right, Rear Tire. Not A Humming Noise A Vibration. What Do You Think??? Please Respond. -thanks, Rob.
Old Aug 14, 2007 | 07:19 PM
Fartpipe's Avatar
Fartpipe
Not sure what it is, do the usual check the lugnuts on all wheels. I honestly have a similar vibe and i'm going down in the garage now to change the rear tires/rims see if goes away on my car. I notice mine on asphalt and not as much on concrete. Weird! Keep us posted.
Old Aug 14, 2007 | 10:52 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Go and check to see that your lug nuts are tight. Then check to make sure suspension bolts are tight.
To Rear Makeing A 'VIBE'
