Fluid Change
Old Aug 15, 2007 | 07:02 PM
supergee's Avatar
supergee
Default Fluid Change
Hey all,
I just wanted to run this by the tech savvy on here to make sure I got everything correct.
I just placed an order for the following:
Motul 600 -4 bottles (for brakes and clutch)
Amsoil Syn 5w30 - 1 case
Amsoil Severe Gear 75w90- 6qts
Amsoil Synthetic Universal ATF- 1 case- (manual trans, '99 FRC)
WIX Oil Filter
WIX Fuel Filter
Since I just bought the car, I'm having all the fluids replaced and all the filters replaced. Did I miss anything? Are my quantities enough for a full flush (esp w/ the brake/clutch fluid)? Is there anything else I should have done for peace of mind?
Thanks for all the help in the past and the future, this forum RAWKS!,
George
Old Aug 15, 2007 | 09:02 PM
Higgs Boson's Avatar
Higgs Boson
Looks good but why 6 qts of gear oil? Rear end takes 2.
Old Aug 15, 2007 | 10:33 PM
supergee's Avatar
supergee
I bought it by the half case. Amsoil preferred membership, it was just cheaper.
Old Aug 15, 2007 | 11:07 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Fluids are correct product and you have enough, though you'll have extra tranny fluid and diff fluid, which is fine. I have a garage full.
I've drained and refilled, then bled my brakes with 2 bottles of brake fluid, so you should be fine with four, even if you refill the clutch as well.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Aug 16, 2007 | 02:08 AM
noahdr's Avatar
noahdr
Coolant?
Old Aug 16, 2007 | 01:19 PM
supergee's Avatar
supergee
Having the shop use whatever coolant they use, same with power steering fluid.
To Fluid Change
