P0335 CKP Sensor Circuit
Old Aug 16, 2007 | 11:07 AM
Gixxer1k's Avatar
Gixxer1k
Default P0335 CKP Sensor Circuit
Please help!
My car is dying, and then not wanting to start again. It will turn over, and occasionally will crank, but I can't even drive it around the block. It is throwing the P0335 code under 10-PCM, and is showing it as current. Does this mean that my CKP sensor is bad, or could it be something else? It is also showing under B0-RFA code U1000 - Loss of communication undetermined.
Everything works on the car when I turn the key, it just doesn't want to start, and when it does, it makes it about 1/8 mile, and cuts out, then shuts down.
It is a 2001 Coupe with 45k on the clock.
Any suggestions as to what could be the problem, or things I could check before having the CKP sensor changed, would be greatly appreciated. Thanks in advance.
Brian
Old Aug 16, 2007 | 11:34 AM
87SAM's Avatar
87SAM
This link may give you a starting point.
http://www.gearchatter.com/viewtopic10351.php
Old Aug 16, 2007 | 04:19 PM
Gixxer1k's Avatar
Gixxer1k
thank you.
Old Aug 17, 2007 | 01:08 AM
5W0P3's Avatar
5W0P3
DTC P0335
Crankshaft Position (CKP) Sensor Circuit
Here you go bud... lets get'r dun!
To P0335 CKP Sensor Circuit
