Another question for underdrive pulley users
Old Aug 16, 2007 | 04:55 PM
MisterC's Avatar
MisterC
Default Another question for underdrive pulley users
Did you find a smaller pulley for your alternator so that you'd always have positive output from your alternator?
If you did, where did you find it?
Thanks,
Old Aug 16, 2007 | 05:05 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default ASP Set of 2 pulleys
Thanks,
I purchased a set of 2 pulleys (1 crank / 1 alt).
Bob K.
Old Aug 16, 2007 | 05:06 PM
gonbad's Avatar
gonbad
Thanks,
No. You will not have a problem as long as you are not running some major stereo amps.
My car runs with 13+ volts on the UD pulley. When it was stock is was 13+ to 14.
Old Aug 16, 2007 | 07:02 PM
ALVETTE00's Avatar
ALVETTE00
Just curious, how much of a real gain do you get from these pulleys?
Thanks,
al
Old Aug 17, 2007 | 09:11 AM
MisterC's Avatar
MisterC
Thanks,
al
Yesterday I was discussing a cam with a major tuner when the UD subject came up. What was said was 'You can get about 6rwhp more if you install a ud when you do the cam. Thus, the original question.
Old Aug 17, 2007 | 09:27 AM
94legaleagle's Avatar
94legaleagle
I think they say an Underdrive Pulley gains you about 5 HP - I got an Underdrive ALT pulley from Lingenfelter performance, together w/ the correct sized belt for it when I installed my CRANK underdrive pulley.
Old Aug 17, 2007 | 10:39 AM
Billdog350's Avatar
Billdog350
I don't have a way of checking the amperage output of the alternator before and after the UD, but my output voltage with the UD is approx 13.7-14.2 when cold idling and drops down to about 13.5 once the battery is charged.
Keep in mind that stock idle is around 650-700 rpm....but when you install a cam your idle is usually much higher than that...closer to 850-900rpm. The % difference that you lose by going to the pulley is made up by increasing your idle rpm for the cam. I did try lowering my idle to around 750-800 and I DID notice a charging issue.....so I keep it around 850-900.
Old Aug 17, 2007 | 02:00 PM
tiojames's Avatar
tiojames
Mime idles between 750-800, no noticeable drop in voltage. Been on since Feb. of 06.
Old Aug 17, 2007 | 02:58 PM
1970-Bronze's Avatar
1970-Bronze
MisterC - That's a pretty valid point. The Tuner will have to raise your idle for the larger cam which will increase the "idle" charging point. If the stock idle speed is 650-rpms and you lose 20%, then new idle speed would only need to be 780 to make up for the loss. You may not need the pulley on the alternator. If you do decide to get the two piece kit, we can install the alternator pulley later if you have a charging problem..... (Had to do that on the Yukon in the summer so I just left it that way).
Something to note: that is 5 hp across the entire curve and not just more HP at the high end like the Cam is going to produce. Total area under the curve is really what you care about since you don't race the car that much....Or do YOU?????
Old Aug 17, 2007 | 04:12 PM
MisterC's Avatar
MisterC
Well alrighty then, the pulley will be in the mix, but consider I still want the HID lights, then what?
Old Aug 17, 2007 | 04:18 PM
MisterC's Avatar
MisterC
Total area under the curve is really what you care about since you don't race the car that much....Or do YOU????? [/QUOTE]
I ain't tellin'.
To Another question for underdrive pulley users
