Door control module and Seat module codes
Old Aug 17, 2007 | 02:57 PM
SiegZ06's Avatar
SiegZ06
Default Door control module and Seat module codes
Does anyone else have continual problems with door control modules and seat control module codes. Mine go off about every 3rd time I drive the car. Today I had a whole bunch of codes pop off at one time. Here is what I got:
PCM
0704
LDCM
2282
2284
1064
RDCM
2283
2285
1064
SCM
0851
2605
1160
RFA
1255
I know this has to be something simple. HELP PLEASE!!
Old Aug 17, 2007 | 03:23 PM
Bruceatlam's Avatar
Bruceatlam
I would start with the "known basic problems" that plague everyone:
1. Battery -- robust and healthy or marginal??? Replace if marginal.
2. Battery terminals all clean and tight??
3. Alternator OK?? Should be around 14.7 volts at alternator at idle
4. Grounds -- clean and tighten
It's either time or money --- there are a number of really simple problems that can set DIC codes. The simple ones you can tackle yourself if you have the time to invest. Rule out the simple before you assume it's complex and then spend a lot of $.
I'm also going to copy and paste a link to another thread that may be more likely to help you. It'll be a separate reply.
Old Aug 17, 2007 | 03:28 PM
Bruceatlam's Avatar
Bruceatlam
Follow this thread -- maybe more on target fro your problem.
http://forums.corvetteforum.com/show....php?t=1602677
To Door control module and Seat module codes
