Diff Oil change, how often?
Old Aug 17, 2007 | 04:41 PM
tk97's Avatar
tk97
Default Diff Oil change, how often?
So I clicked over the 100,000 mile marker a couple weeks ago and I got thinking, I've never had the diff oil or tranny fluid changed. I'm sure these need to be done, but I was just wondering how often they should be changed on our cars? I have a 97 MN6.
Old Aug 17, 2007 | 05:27 PM
Buckskinner's Avatar
Buckskinner
Default seals
When tha axle seals leak bad enough to tick ya off. I changed mine @ 210,000
Old Aug 17, 2007 | 05:31 PM
tk97's Avatar
tk97
Good to know!
Old Aug 17, 2007 | 09:40 PM
waterzap's Avatar
waterzap
Its pretty easy to do. Hmmm....lets say every 2 years or 20,000 miles. Yup..that should do it. The fluid does get hot and breaks down. Do it now, and every few years. Get a set of ramps, you can do it yourself pretty easily. My shifting really improved when I changed the tranny fluid.
Old Aug 17, 2007 | 09:53 PM
VinceAD's Avatar
VinceAD
210,000! That is awsome!
Old Aug 18, 2007 | 01:14 AM
Point & Shoot's Avatar
Point & Shoot
I change both diff & tranny at 15 - 20K ...... to me it's cheap insurance given that the car is driven daily, often in stop and go traffic.
Old Aug 18, 2007 | 07:47 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Get the car up high enough so you have access to both transmission and differential.
The differential has 2 10mm hex plugs, one for draining, I believe it's on the passenger side at the low point. The fill plug is on the rear of the differential facing the back of the car.
Use the same method, drain then fill. The Differential takes 2 quarts of fluid.
While you're under there service them both. I use Royal Purple products, see my signature below....
Old Aug 18, 2007 | 10:26 AM
Buckskinner
Default my bad
actual it wuz at 203,000 when ah had tha trans rebuilt. 210,000 ah dun tha harmonic balancer
Old Aug 18, 2007 | 04:29 PM
tk97's Avatar
tk97
Thanks for the info . Sounds easy enough to do.
Old Aug 18, 2007 | 04:39 PM
Oldvetter's Avatar
Oldvetter
My MN6 transmission needs synthetic fluid changed every 50,000 miles. Last time it ground going into 6th gear, changed fluid and fixed that.
I have never changed differential fluid, and am at 106,000 miles.
Old Aug 18, 2007 | 07:15 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I changed my differantal fluid a couple months ago after putting on 1000 miles on my 3.90s. Itwas so easy a cavemen could do it
I have my tranny fluid changed when the clutch was being replaced the 2nd time. I asked the Mark the mechanic as ECS who was replacing my clutch and he said it depends on how much I liked my car. I told him since he was installing the 2nd new clutch in 3 months, I really dont like the car now, but change the fuild anyway. It was right there and easy to do.
I wont change them again for another 5 years or 25,000 miles. Which ever comes first. I put on about 3000 miles a year. The car is 7 1/2 years old and has 23000 miles. I change the cam more than anything else.
To Diff Oil change, how often?
