***Cam size***
Old Aug 17, 2007 | 08:20 PM
SLPRC5's Avatar
SLPRC5
Default ***Cam size***
Anyone using a Comp Cam 220/224 .530/.534 LSA115
If so how do you like it and the power it is putting down.
Sleeper
Old Aug 17, 2007 | 08:26 PM
TLewis4095's Avatar
TLewis4095
That is a pretty mellow cam....what are your goals?
Old Aug 17, 2007 | 09:10 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Baby cam
Old Aug 17, 2007 | 09:23 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
What are your goals. That's a really small cam. If there's one thing I learned - when in doubt go one bigger. I've gone through 5 cams. Need to ask yourself what type of driving do you plan to do, e.g., mild/stock-like, drag racing, road course tracks, do you want the torque down low, mid range or up high, etc. Stock heads or aftermarket. Many variables.
Old Aug 18, 2007 | 03:19 AM
SLPRC5's Avatar
SLPRC5
I have a 224/224 .567/.567 LSA114 cam and I hate the sewing machine sound...I have installed, caddy lifters, 7.425 push rods, Harland Sharp roller rockers and nothing has helped with the sound.
I was wondering if the smaller cam with a smaller lift would not give it as loud a sewing machine sound.
With the cam in the engine now I wanted to reach 400RWHP.
I don't plan to race the car, it's a DD just wanted 400 RWHP on the street.
Thanks,
Sleeper
Old Aug 18, 2007 | 12:03 PM
voda1's Avatar
voda1
GM went from .500 lift stock cam to .550 lift Z06 cam without the noise. I'd like to see a dyno graph where the Z06 cam is optimized. i.e. DCR = 8.7 for 93 octane, AFR heads, AR header, ported FAST90/90, possibly injectors,
UD pulley, EWP, roller rockers, tune. Should make 400 rwhp with all the goodies. With the exception of the EWP, should be good for daily driver.
Old Aug 18, 2007 | 01:12 PM
SLPRC5's Avatar
SLPRC5
What year ZO6 cam has a .550 lift?
A member said the noiser valvetrain noise comes in with a cam above550. So this may be true.
I have all you mentioned so I should be close to 400 with a cam that has a lift under .550.
Thanks,
Sleeper
Old Aug 18, 2007 | 01:28 PM
zeevette's Avatar
zeevette
I have a 228/232 with .600 lift, and it's no noisier than the stock one, that I can tell. Of course, the car's got headers, which have a kind of mild beans in a tin can sound, too. I don't think it's your parts, but maybe it's your lifter preload setting. Do you have headers? That may also be part of where the sound is coming from.
Old Aug 18, 2007 | 08:17 PM
voda1's Avatar
voda1
Thanks,
Sleeper
The 02 & up Z06. see this http://www.c5registry.com/2k2z06/page4.htm
Old Aug 18, 2007 | 08:42 PM
SLPRC5's Avatar
SLPRC5
Thanks for the info..I had a 2002 ZO6 installed before going to the 224/224 and the sewing machine wasn 't bad at all.
Old Aug 18, 2007 | 09:24 PM
edcmat-l1's Avatar
edcmat-l1
Sounds like you have mechanical issues. No pun intended.
We've done bunches of cams over .600 lift with little to no noise.
Currently have a LS2 with a +.600 24X/24X custom grind that makes NO noise.
Old Aug 18, 2007 | 10:32 PM
SLPRC5's Avatar
SLPRC5
What can be the "mechanical issuses"? All of the LS engines have some sort of sewing machine sound. When a larger cam is installed it brings out a louder sound from the valve train...
Thanks,
Sleeper
Old Aug 18, 2007 | 10:37 PM
Gray Ghost GS
I'll bet you heard the "sewing machine" noise more once you installed your LG Pro headers because any header will allow more valvetrain noise to be heard because the noise is going through relatively thinner stainless steel material compared to the heavy stock cast iron manifolds.
Recommend going back to the 7.400 pushrods because you may be adding excessive lifter preload with the longer pushrods (double check), and probably not reducing the noise any. The 224/224 .567/.567 114 is a good popular cam size. More aggressive ramp rates from the cam could increase this type of noise from the lifters/rockers, e.g., Comp Cam XE vs.XER and higher spring pressure rates.
Old Aug 19, 2007 | 12:55 AM
SLPRC5's Avatar
SLPRC5
Recommend going back to the 7.400 pushrods because you may be adding excessive lifter preload with the longer pushrods, and probably not reducing the noise any. The 224/224 .567/.567 114 is a good popular cam size. More aggressive ramp rates from the cam could increase this type of noise from the lifters/rockers, e.g., Comp Cam XE vs.XER and higher spring pressure rates.
Okay,
I'm surely not good at this. I do understand that the LG headers have larger primary tubes that the Bassani headers I had and the Bassani had ticker primary tubes..so I agree that the sound increased when the LG headers were installed.
Now the question is. What length push rods are people using with this cam. I had 7.4 push rods and the sewing machine sound seemed louder. So after measuring the base circle and getting 1.498 mvvette97 did the conversion for me and came up with a 7.425 push rod.
I have the Patriot heads 243 casting with their gold springs. Someone mentioned using a thicker push rod like the Trend .110 wall.
Sleeper
Old Aug 19, 2007 | 01:02 PM
TLewis4095's Avatar
TLewis4095
Proper valvetrain geometry & pre-load should result with very little valve train noise. Just ask some of our large cam customers.
Old Aug 19, 2007 | 01:41 PM
SLPRC5's Avatar
SLPRC5
So whats the fix? It may be coming from the thin wall LG headers...I had Bassani LT headers on before and they are thicker and it seemed like less noise...I feel like I'm grabing for straws now on this problem..
Old Aug 19, 2007 | 02:32 PM
edcmat-l1's Avatar
edcmat-l1
Just guessing, cause thats about all I can do over the 'net. I'd say put a longer puhrod in it. The sound clip you sent me sounded like it didnt have enough lifter preload.
A good way to check is pull a valve cover, and see if the rockers have any slop in them. While you're in there, you can check if the lifters seem bled down.
There has to be a reason. Thats not normal.
To ***Cam size***
Old Aug 19, 2007 | 03:11 PM
SLPRC5's Avatar
SLPRC5
So you think longer push rods than 7.425 could be the fix? Next would be 7.50 pr. and what it they are too long; damage to the lifters or pistons?
Old Aug 19, 2007 | 03:31 PM
edcmat-l1's Avatar
edcmat-l1
I would think you can get 7.450s. if they end up too long, you'll hold the valves open slightly, and it wont start, or start and run terribly.
You would really have to over shoot the length to cause any damage.
You have about .200 worth of lifter preload, so you've got some room for error.
Old Aug 19, 2007 | 04:49 PM
SLPRC5's Avatar
SLPRC5
I'll do as you suggested in the PM...pull a valve cover and check to see if there is any play in a set of push rods that are on a cylinder that is TDC and if so it will be a set of 7.450 PR. needed?
