Cam advice
Old Aug 17, 2007 | 09:06 PM
flynnstone's Avatar
flynnstone
Default Cam advice
So i've been researching different setups on CF and also on LS1tech, and would like some additional opinions/advice for what im trying to accomplish.
The car is a 00 C5 6spd, LS6 intake, LG Long-tubes, full exhaust, vararam intake.
My goal is to achieve mid/high range power, and I've been looking into the G5X3 cams. I'll most likely stick with the stock heads for awhile.
All help is appreciated.
Matt
Old Aug 17, 2007 | 09:16 PM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
G5X3 is a good cam for what you are looking for. Our Whiplash cam is very similar and I have it in my car. Check my sig for a vid of what it sounds like. Either one of these cams will make stupid power above the 2400 RPM range. Hope this helps.
Old Aug 17, 2007 | 09:25 PM
flynnstone's Avatar
flynnstone
What are the specs on your whiplash cam?
Old Aug 17, 2007 | 09:31 PM
Arcane1's Avatar
Arcane1
Supporting Tuner
It is in the 240's but the rest is proprietary information.
Old Aug 17, 2007 | 10:20 PM
flynnstone's Avatar
flynnstone
I wouldnt buy a cam without knowing what im tossin into my motor...Do many people just not care?
Old Aug 18, 2007 | 01:40 AM
rustyguns's Avatar
rustyguns
i don;t think it is they do not care...they just don't know!
Old Aug 18, 2007 | 05:56 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
LGM & ECS (just to name two name-brand shops) also have proprietary cam grinds.
I have installed many, many LGM & ECS cams in our customers' cars without knowing the exact specs of their respective cams.
You trust the Tuner, not the specs.
Stephen
LGM G5X4
To Cam advice
