jacking question
Old Aug 19, 2007 | 11:26 AM
Munky's Avatar
Munky
Default jacking question
I have read many of the posts on jacking a c5 so far, and have one question.
can I use a hydrolic low profile jack and jacking pucks to lift each corner one at a time, and put a jack stand under each lifting point without damaging the car?
I hope this isn't too stupid a question, but i wanted to ask before I begin my brake/wheel work.
I am only going to be lifting one end at a time, maybe only one corner, but I certainly don't want to eff anything up.
thanks.
Old Aug 19, 2007 | 11:39 AM
rws.1's Avatar
rws.1
This is the safest way....
http://forums.corvetteforum.com/show...g&forum_id=103
Old Aug 19, 2007 | 12:37 PM
Zozzie's Avatar
Zozzie
Try these links -
http://forums.corvetteforum.com/show...ht=wooden+pads
http://www.z06vette.com/diy_lift.php
Old Aug 20, 2007 | 11:35 AM
jovette's Avatar
jovette
thanks.
How are you planning to place a jack stand under the lift point, if you already have a puck / hydraulic jack under the lift point?
Old Aug 20, 2007 | 12:32 PM
Munky's Avatar
Munky
I obvioulsy wouldn't be putting it where I was jacking the car, but rather under the front cross member.
I am simply doing some break work, and wanted to know if I will damage my car by using the pucks to get each front corner up, put a jack stand under the cross member, and successfully get the entire frong in the air without making the wood accesories mentioned in other threads.
I apologize about not being clear.
Old Aug 20, 2007 | 04:11 PM
jovette's Avatar
jovette
suggest you place a 2"x4" or 2"x6" under the cross member before dropping it on the jack stand. Not sure how stable that will be for you when you only have one side in the air. My '00 coupe is very stable when I jack it up using the 2"x6" cross member piece I made per the forum jacking instructions, after driving the car up on the wooden ramps I made out of 2"x12" pieces, but then, I have the car jacked up on both sides, so it sits level across the front when supported by two jack stands.
Old Aug 20, 2007 | 05:33 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I do it kind of the caveman way.......jack a corner, stack something like 3 pcs. of 2x4 under that tire. go to the other side and do the same thing. That gives me room to get the low profile jack under the front end . I then place 2 jack stands under the cross member (leaving the floor jack under there also)
To jacking question
