HELP!!! Adding a factory 12 disc changer
I would contact Gene at Karshop in FL
http://forums.corvetteforum.com/show....php?t=1740665
Follow this:
.Anyway,i found the post this gentleman had,and it worked ok...
on an "un-cut" changer harness you have 2 connectors. on one connector you have the positive and negative audio inputs, left and right (4 wires total), that connector is called the "4 wire" connector, the other connector has power, ground and data (3 wires total) and it's called the "3 wire" connector.
all '97 to '99 C5's have the "4 wire" connector in the passenger footwell, it's the "3 wire" connector that is usually missing.
the easiest way to hook up the changer harness is to plug the harness into the existing "4 wire" plug in the passenger footwell and hardwire the power, ground and data wires behind the fuse panel in the footwell.
BUT, since someone hacked up your harness and decided to do it "the hard way" you will need to get the color codes for the wires in the harness, you may want to invest in getting a service manual for your car, it has the wiring diagrams in it.
maybe my description of the wires can help you in some way..
