methanol NEWBIE question
Old Aug 19, 2007 | 05:57 PM
D C's Avatar
D C
USMC (retired)
Default methanol NEWBIE question
Sorry meth newbie questionHow does methanol help in high HP/supercharged setup? If you run and tune with a methanol setup, is it alright to run without it or do you have to retune without?
Is it constantly on....does methanol get injected at all times or is there a time when it comes on?
Old Aug 19, 2007 | 08:46 PM
speedsk899's Avatar
speedsk899
I have played with a couple of methanol kits. The ones that I have seen are activated at a preset boost level, nothing under 3lbs I think (could damage the motor). It helps by cooling the air, and intake, and making a denser air charge, I have seen it drop 70 degrees on an intake and some people say that you can see gains of 1hp per degree drop....I'm sure it is not that much but it is worth your time. Good luck
Old Aug 20, 2007 | 08:17 PM
Dave concrete's Avatar
Dave concrete
I have a 581rwhp ECS novi car,using there meth kit.Meth is like having another intercooler it helps lower charge temps and more importantly it helps atomize fuel to achieve clean even cool burn.
To methanol NEWBIE question
