Just thinking out loud,but.....
Old Aug 21, 2007 | 01:13 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Default Just thinking out loud,but.....
Well,I was thinking about the hp rating difference between the ls6 and the ls1.
Ls1=350
ls6=405
That's 55 hp difference with the main difference being the heads and cam
Now,as discovered by myself and confirmed by a few others here,just swapping stock 243's onto an ls1 will only net @ 15 hp,give or take
Ok,.........that leaves the cam ...right?
Well,the z06 cam is really not ALL that much bigger,certainly doesn't seemlike it would be responsible for another 40 hp!
And,when talking about swapping other much larger cams,in comparison( 224/228 range),many say to only expect 30 or so hp.....unless you get into real large"gorilla cams"
So,is it just that this setup is optimally matched for the best results?
Because I can only imagine an ls6 cam swap cam alone being good for only what?..........15-20 hp?
Add those two up and it comes to35,that leaves 20 hp!!
I can only summize that it is an optimal match to achieve those numbers...So, here is another question.....
ls1 block @350 hp adding ls6 cam only =???hp?
ls1 block @ 350 hp adding 243's only =???hp?
Adding both = 405
What's your thoughts?
Old Aug 21, 2007 | 01:20 PM
LF97C5Vette's Avatar
LF97C5Vette
Yeah - I've always understood that the effects are more than just additive...
So if 243s = X Gain and the LS6 Cam = Y Gain the total gain from doing both would be greater than just X+Y. Because they compliment each other...
Has anyone tossed LS6 Heads and an LS6 cam on an 01+ LS1 and Dyno'd it? I would imagine they'd see somewhere near 350whp which is about right...
-Dan
Old Aug 21, 2007 | 01:32 PM
edcmat-l1's Avatar
edcmat-l1
-Dan
Ask and ye shall recieve!!
01 Camaro, LS6 heads and cam. Unported...tuned
Old Aug 21, 2007 | 01:38 PM
LF97C5Vette
Yup - so that pretty much sums it up... lol
Perfect Graph!
-Dan
Old Aug 21, 2007 | 02:32 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Ls1=350
ls6=405
Adding both = 405
Joe, one point to remember, compare rwhp and not the GM hp rated at the crank!
The average stock LS6 rwhp is usually around 336 which an LS1 will achieve with intake and headers!
I think and LS6 with intake and headers usually average in the 360`s give or take.
Of course a tune can always improve those numbers, so all in all the numbers at the rear wheels seem to add up correctly being that the LS6 heads run a higher comperssion.
Also, don`t forget that our auto trans will always dyno lower than the manual cars........ go for the after market cam with at least some ls6 heads and you`ll be happy!
Old Aug 21, 2007 | 02:56 PM
flynbya2's Avatar
flynbya2
Just thinking out loud at this point buddy..
You know I already have the heads on right?
The reason I was going with crank #'s was to omit the powertrain loss in the equation,.Just trying to figure that 55 hp out....because I only saw maybe 15or 20 max with the heads
BTW Rick,
I think I want that UD pulley!!!
Old Aug 21, 2007 | 03:36 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Air Box & Ti Catback
Don't the LS6's have a different airbox. I know the Ti catback is better flowing.
Bob K.
Old Aug 21, 2007 | 03:46 PM
flynbya2's Avatar
flynbya2
Bob K.
Yes,
I suppose they do....
I guess I pretty much discounted that as much of a hp increase,maybe wrongfully so,but I wouldn't think it would account for all that much....but.........
To Just thinking out loud,but.....
