Where Does This Braided Line Go?
Old Aug 21, 2007 | 10:52 PM
RrCoX22's Avatar
RrCoX22
Default Where Does This Braided Line Go?
I was messing around near the driver side manifold and saw this line unplugged. I can't find the other end as it seem to go somewhere in the bellhousing area. Any ideas? Thanks
Old Aug 21, 2007 | 10:56 PM
mrC5er's Avatar
mrC5er
With the nylon zip ties, it doesn't appear to be factory.....
And although I've never seen one, it's possible it's one of those speed bleeders for the clutch slave cylinder. (Is the car a 6-speed, or automatic?)
Anybody that knows, does that sound right?
Old Aug 21, 2007 | 11:01 PM
RrCoX22's Avatar
RrCoX22
no it the one that just is hanging there... i agree it look like it's part of the slave cylinder or master cylinder brake line but can't figure it out. oh and the car is an M6
Old Aug 21, 2007 | 11:43 PM
ILM-Express's Avatar
ILM-Express
MFIC
It does look like a remote bleeder, lucky you !
Just zip tie it away from that exhaust manifold
Old Aug 22, 2007 | 12:04 AM
GreyGT-C's Avatar
GreyGT-C
definately a remote clutch bleeder
Old Aug 22, 2007 | 01:31 AM
ILM-Express
MFIC
Old Aug 22, 2007 | 03:44 AM
RrCoX22's Avatar
RrCoX22
ok so what's its function... how does this work?
Old Aug 22, 2007 | 05:58 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It allows you to bleed the clutch slave cylinder without having to go up into the transmission tunnel to reach the OE location. Very convenient...
Old Aug 22, 2007 | 01:39 PM
DRR's Avatar
DRR
This link will help...
http://forums.corvetteforum.com/show....php?t=1789926
Old Aug 22, 2007 | 02:05 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
That is a remote clutch bleed line. It allows you to move the bleed screw for the clutch hydraulics up into the engine bay area. In the oem configuration you must remove the center section of your exhuast and the tunnel plate to access it.
You'll want to wrap that line with some fuel line to prevent the braided line from chafing on the parts around it. I almost had my car catch fire when my line rubbed through my fuel line on the firewall. Our fuel lines are composit and the braided stainless made quick work of it.
Mine is zip tied to my hood relase cable running under my cowl. I bleed my clutch once a year, between that I used the turkey baster method to suck the reservoir dry and refill.
Here's where I have mine routed - you can see it sticking out in the lower right part of this picture behind the brake fluid reservoir above the brake booster. I have the end covered w/ a vaccum cap.
It also tells me your car may have been modded and put back to stock. At least it has a new clutch put in as thats when most people add the bleed line.
To Where Does This Braided Line Go?
