Euro T-84 headlight users.....
I know I'm definitely getting the Phillips HID lighting.
Just not sure to stay with stock lenses or go Euro (glass).
Anyone??
[Modified by indypace78, 6:38 PM 11/6/2001]
They work great with the 80W piaa hyperwhite bulbs, much improved over stock.
Only had two drivers flash their hi beams at me in 7000 miles, no problem!
go with the glass!
Or, if you want overkill, use the entire Euro assembly (complete unit with motors, etc.), not just the headlight shells. Runs about $350 compared to $35, but some folks swear by it. See Bob Wendorff at http://www.fichtnerchevrolet.com .
I didn't realize they make a real HID system for the C5 yet, just a conversion. If you go with that, don't use the T-84s, because you won't have high beams for the deer in Bucks County.
I would disagree with EHS that this is overkill in a functional sense, since you end up with a very clean upgraded version of the export setup that retains all of the stock adjustment features in mechanically solid units. However, with what GM has done with the prices, this approach has unfortunately become financially ridiculous.
It seems that the WEIGHT of the (glass) Euro lenses can impede the ability of the STOCK headlight door motors/actuators to CLOSE the headlight doors properly (ie. they stay up when you turn the headlights off) UNDER CERTAIN CONDITIONS, such as if you turn the headlights OFF after you shut off your engine.
I've had this happen to me several times, BUT NEVER (so far) if I shut the lights off WHILE THE ENGINE IS STILL RUNNING. It seems (likely) that the 12 volts or so available to the actuators when the engine is off (compared to the 14 or so WITH it running) is NOT enough to allow the actuators to come off their 'open, over center lock-point' and close properly.
BTW: this is a CONFIRMED (though not insurrounatble and not too frequent) PROBLEM. I checked with GM and they indeed DO make and use a different motor/actuator for vehicles equipped with the Euro lights...
That said, however: I would still say 'Go For It'. My setup with 130/100w lamps is GREAT and, as long as properly aimed, 'by the book', has NEVER caused anyone to 'flash me' in a request for a 'dim'...
You won't BELIEVE the difference they make when driving at night...
Where can I purchase this different motor/actuator? part #,etc.?
Thanks.
:seeya
Joe
For what it's worth, Bob says he has sold about 250 T-84 assemblies to date, and only one (1) complete set, i.e., with the actuators. Says that even GM hasn't been able to tell him what the difference is between the Euro and US actuators, other than the part number and price. Has "received very few" complaints on the 250 units he sold. The trick for no shake seems to be proper adjustment of the headlights/motors/stops.
Hope this helps. :smash:
