LS2 Throttle Body
Old Aug 22, 2007 | 02:08 PM
Justin01SS's Avatar
Justin01SS
Default LS2 Throttle Body
Going with a FAST intake and a 90mm throttle body. Are the LS2 GTOs and the LS2 Vette TBs the same? I cant find a different part number listing for the GTO (Vette is 12570790 ) but wanted to be sure before I pulled the trigger on the TB.
Thanks!
Old Aug 22, 2007 | 04:05 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Thanks!
I'm not sure about the year of the crossover but initially the GTO came with a cable operated 90 mm TB. Later on they switched to an LS2 style throttle by wire unit.....that's the one you need and it is the same. Just make sure your getting a throttle by wire TB...NOT the cable operated version.
Tony
