Hud Six Speed Shift Light
Old Aug 22, 2007 | 07:14 PM
dons972's Avatar
dons972
Default Hud Six Speed Shift Light
I Read In This Forum Under C5 Hidden Secrets That The Factory Hud Has A Shift Light. Does Anyone Know If This Is True And How To Activate It?
Old Aug 22, 2007 | 07:21 PM
gpracer1's Avatar
gpracer1
Go to over 5600 or so and it will say "shift" on the HUD.
Old Aug 22, 2007 | 08:40 PM
dons972's Avatar
dons972
Default Hud
Old Aug 22, 2007 | 10:51 PM
Corvette Monkey's Avatar
Corvette Monkey
You let the secret out of the bag.
But I don't find it too helpful as it's green and blends in with everything else in the HUD.
The LS1 doesn't taper off like most motors as it winds up, so I end up using the bounce off the rev-limiter as my shift light too often (doh).
Old Aug 23, 2007 | 11:31 AM
phoenixfoundmac's Avatar
phoenixfoundmac
It does have a shift light. If you're adept at focusing on the HUD while driving then it is invaluable. It says shift now at 5750 RPMs if I'm not mistaken. As you're driving, when you see that extra little light come up in your field of vision you shift. I personally wait a split second or so after I spot the light to shift, because the car still benefits from another 100-150 RPMs.
Old Aug 23, 2007 | 12:14 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Are there "shift lights" without HUD?
To Hud Six Speed Shift Light
