LED replacement for climate control backlight?
Old Aug 22, 2007 | 07:55 PM
lakedude's Avatar
lakedude
Default LED replacement for climate control backlight?
I did a search and found info on diming climate control displays. My main display is fine but the backlights behind the buttons have all burned out. A friend told me to get em replaced with long life LEDs. Anybody done this? Did you do it yourself or get service? How much did it cost/where?
Sorry in advance if there are already threads on this, couldn't find em if there are....
Old Aug 22, 2007 | 09:52 PM
ALVETTE00's Avatar
ALVETTE00
lakedude...read my thread!!!
http://forums.corvetteforum.com/show....php?t=1790013
Call Gene at gmparts!!!
-al
Old Aug 22, 2007 | 10:16 PM
lakedude's Avatar
lakedude
-al
Thanks but I was interested in relamping with LEDs not buying a whole new control unit. The unit and the display work fine, only the button's backlights are burned out.
I found exactly what I was looking for at LEDGauges but they want $140 bucks for what I'm guessing is less than $10 worth of LEDs? Scroll down to the Corvette section....
http://ledgauges.tripod.com/camaroproducts.html
Old Aug 23, 2007 | 06:55 AM
HeadHunter1's Avatar
HeadHunter1
Yes, I have seen it done. They took out the little bulb holder and converted it to an led holder with the resister on the back side. and soldered it up. Looked a little time consuming, but would be cheap. For the resister values you can use the following site http://metku.net/index.html?sect=vie...calc/index_eng
For blue, you are looking at about 330 ohm - 470 ohms depending on the led.
To LED replacement for climate control backlight?
