Tire pressure sensor question...
Old Nov 6, 2001 | 09:43 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Default Tire pressure sensor question...
My left rear tire pressure sensor tells me my tire is flat first thing in the morning:confused: . I know it is not as the tire gauge reads 30 psi. After the tires warm up the DIC reads normal tire pressure. Do I have a sensor going bad or does it need "relearning"? The other three work fine. :seeya
Old Nov 7, 2001 | 12:11 AM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Tire pressure sensor question... (89ragtop)
Have you recently had the tires changed? When I had mine changed the tech accidentally swapped the front rims. I kept getting a warning that the left front tire was low and every time I checked it was fine. Then one day I checked the right front tire and found it was low while the system said it was fine. A quick reprogramming solved the problem.
Bill
Old Nov 7, 2001 | 10:35 AM
Paul R's Avatar
Paul R
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Tire pressure sensor question... (Bill Dearborn)
Bill makes a good point. make sure one of your other tires is not low on air and the sensors programmed to the wrong wheels. If they are all OK, then I would go to the dealer because the sensor probably has a problem.
To Tire pressure sensor question...
