Changing Fan On/Off while keeping 172° Thermo?
Old Nov 7, 2001 | 11:54 AM
Jeff Wilson's Avatar
Jeff Wilson
Default Changing Fan On/Off while keeping 172° Thermo?
With the Stock 172° thermostat, & stock programming the cooling fans are set as follows:
Fan 1 on/off at: 227°F/218°F
Fan 2 on/off at: 235°F/228°F
Is there a problem setting them to this:
Fan 1 on/off at: 184°F/175°F
Fan 2 on/off at: 194°F/185°F
Without changing to a 160° Thermo?
Old Nov 7, 2001 | 12:18 PM
Jeff Wilson
Default Re: Changing Fan On/Off while keeping 172° Thermo? (Buckmaster)
Yes, they are controlled by the PCM. A PCM re-program can do it.
I realize it can be done, I gues I should have been more clear in my question....is it advisable?
Old Nov 7, 2001 | 03:06 PM
6Speeder's Avatar
6Speeder
Default Re: Changing Fan On/Off while keeping 172° Thermo? (Jeff Wilson)
If you really have a 172 thermostat it'll cause no problem. My concern is that you state you have a "stock 172 thermostat". The stock C5 thermostat opens at 195, not 172. If you have the stock 195 thermostat and lower your fan on/off temps, the fans will run all the time after first warmup of the car. Probably not good for long term life of the fan motors. :chevy
Old Nov 7, 2001 | 03:22 PM
Jeff Wilson
Default Re: Changing Fan On/Off while keeping 172° Thermo? (6Speeder)
Whoops! I just assumed the 172 was stock from some other threads I've read. I am stock, so I guess it's 195. No need to turn the fans on so soon then, huh?
To Changing Fan On/Off while keeping 172° Thermo?
