hey guys i just bought another c5 1999 i am having common fuel gauge problems also it turns over for a few secs be4 it starts.I have checked all the posts but not really sure if this one problem is causing the other or possible 2 different ones?i added the techron tonight,then i did some searching, and i seen something about a valve or y pump etc,let me know what u guys think so i can dig into it tommorow.thanks Brian
.....also it turns over for a few secs be4 it starts......
Send a PM to LoneStarFRC http://forums.corvetteforum.com/priv...=newpm&u=20746
He had a similar problem with his '99. It turned out to be a check valve which maintains fuel pressure between the fuel pump and fuel rail when the ignition is off.
i will try the fuel pressure test first,and see what code i have i think when i checked the code the other day it was a high voltage fuel sensor code,but i cant remember the code number.
