oil consumption?
Old Aug 27, 2007 | 09:49 AM
02gt350's Avatar
02gt350
Default oil consumption?
Any of you head cammed guys notice you eat some oil? I have gone 2900 miles since my head cam swap and i got a low oil light. Checked the dip stick when it was bone cold and was fairly low. but dosnt seem to smoke nor leak anywhere
Old Aug 27, 2007 | 12:19 PM
jovette's Avatar
jovette
Suggest you check your valve guide seals. I recall reading about a few members experiencing oil burning due to bad valve guide seals following a head change.
Old Aug 27, 2007 | 01:47 PM
BlackZ06's Avatar
BlackZ06
A quart in 3,000 miles ... that's not bad at all .... I'd do as Bugs Bunny says and "unlax" ..... that's not an oil burner. If you burn more than a quart in about 1,000 miles, then it is time to start "worrying" aboout it. Until then, go and enjoy that ride !!!
Old Aug 27, 2007 | 09:57 PM
davey1's Avatar
davey1
i agree. 1 qt 3000 miles i would not worry about that.
Old Aug 27, 2007 | 10:44 PM
SLPRC5's Avatar
SLPRC5
I had the same problem after a cam and head change.
My LS1 had no oil usage between oil changes until the H/C change.
Problem was solved with a catch can. Although it doesn't stop the usage but saves it from going into the intake.
I suggest you get a catch can ( if you haven't already) and the new replacement PCV.
Good luck
To oil consumption?
